I’ve sprayed 3 coats of slick sand and started sanding...right now using 240 grit...should I be using 150 now? Planning on 3 coats of primer, then sealer after the slick sand? 150 cuts it much faster than 240 but concerned over scratches? One door took about 4 hrs, normal?
