ReinCarNation
Thanks Thanks:  2
Likes Likes:  3
Results 1 to 22 of 22
Thread: Unscheduled maintenance!
    Sorry about that folks, we were hit with an unexpected server migration. Everything is up and running again but let me know if you find any issues.
    Thanks!
    Senior Member RickP's Avatar
    Boyertown, PA
    lights are back on!
    mburger's Avatar
    Punta Gorda FL
    Thanks David for all the work you do with the forums.
    Mark
    Mk1, Frame #1929 stock 1990 EFI 302, T5, 8.8 axle 3:55, PS, Heidts, heat, fresh air vents, Russ Thompson Turn Signal mod, windshield wings FFR front lower control arms, Speedhut gauges, Alex's glovebox, cup holders. charging ports. 70K on the motor and 7,200k on the car.
  4. Thanks David Hodgkins thanked for this post
    Senior Member RoadRacer's Avatar
    Thanks, looks good so far!
    Aerodynamics are for those who can't build engines - Enzo Ferrari
    FFR33 coupe #997, ordered 2/20/17, delivered 4/15/17, build thread
    Planned: 350SBC, TKO600, hardtop, no fenders/hood, 32 grill, 3 link, GT500 wheels
  6. Likes David Hodgkins liked this post
  7. #5
    Glad it worked out. "Unscheduled maintenance" huh? I worked in IT so pretty sure I know what that means.
    Is it just me, or is the site a little sluggish now? Pages don't seem to load as quickly. Otherwise, all good.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
  8. Likes David Hodgkins liked this post
  9. #6
    mburger's Avatar
    Punta Gorda FL
    I work in IT and last week had some “Unscheduled Maintenance “ when the fire suppression company didn’t turn the breakers back on for the data center AC units after their testing.
    Mark
  10. #7
    Yeah, it is sluggish. I'm getting some feedback about that issue via PM. I've asked the hosting service about it and will report back.
  11. #8
    Senior Member AZPete's Avatar
    I've never worked in IT but from this I've learned that pulling my engine to replace a blown head gasket is just "unscheduled maintenance". I feel better now.
    818S/C : Chassis #25 with 06 WRX 2.5 turbo, ABS, cruise, PS, A/C, Apple CarPlay, rear camera, power windows & locks, leather & other complexities.
  12. #9
    Senior Member 42Bfast's Avatar
    Feb 2017
    Pensacola
    And all this time I thought it was due to the Sheetrock dust in my router. :-)
    (Roadster build on temporary hold while house renovation)
  13. #10
    Hot Smokin' Tamales! The site is FAST right now!
    I think we're good to go.
  14. #11
    Kirkland, WA
    "Unplanned maintenance" isn't as bad as RUD - Rapid Unplanned Disassembly. Depending on the magnitude, may also be known as a 'yard sale'.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, Roller: 12 Jan 2018
    Forte: 2016 Coyote & cover, alternator, engine controls, clutch kit, bellhousing, Moroso pan, TKO600, midshift, 3.55 axle, 190lph fuel pump, Spectre air inlet and filter. Breeze: battery forward and switch, fuel pressure regulator and braided hose, radiator shroud and mounts. Replicaparts: radiator panel, under dash panel, weathertight connectors.
  15. Likes Just puttering liked this post
  16. #12
    https://thefactoryfiveforum.com/show...743-Forum-slow
    https://thefactoryfiveforum.com/show...ething-Changed
    https://thefactoryfiveforum.com/show...ached-Warnings
    I wanted to reply to this thread to give an update to the speed issue with the forum over the past 9 days.
    The issue surfaced once the site was "clamped down" after the emergency migration. It has taken this long to ID and mitigate the underlying cause. The site is heavily patched at the moment and an overlay is scheduled.
    We're not out of the woods quite yet but you should have noticed the speed improvement. I don't know if it's temporary or not, but I'm looking into status for that.
    I know this is somewhat of a cryptic response but until I know all the facts it's the best I can do. For now. The situation is still fluid and as soon as I have another update I'll let you know.
    Last note: The "Like" feature was NOT the cause as far as I know.
  17. #13
    mburger's Avatar
    Punta Gorda FL
    The site has been FAST all day! Great work! Hoping we are out of the woods.
    Mark
  18. #14
    Thanks, David.
  19. #15
    Boyertown, PA
    Thanks for all your hard work David.
  20. #16
    As you may have noticed, we had to shut the forum off for a bit to do some upgrades. It's up and running again. Not sure if we will need to pause it again...
    Stay tuned!
  21. Thanks Wt4Go thanked for this post
  22. #17
    Don't look now but I think we're back up to speed!
  23. #18
    Parker, CO
    Thank you for working through the issue. Slow doesn't work in this hobby!
    There are 10 types of people in this world;
    those who understand binary and those who don't.
  24. #19
    10 days later I've closed the ticket on the migration as successful (finally)
    As you were...
  25. #20
    mburger's Avatar
    Punta Gorda FL
    Thank you thank you thank you.
    Itís almost too fast. Anyway to slow it down a bit?
    I crack myself up. (Iím here all week. Fortunately itís Wednesday...)
    Mark
  26. #21
    Quote Originally Posted by mburger View Post
    It’s almost too fast. Anyway to slow it down a bit?
    I crack myself up. (I’m here all week. Fortunately it’s Wednesday...)
    Actually, during the early testing they really opened the spigot. Sometimes it was absolutely lightning fast. It was actually noted in the test results to throttle the bandwidth!
    Speed = $$$. How fast ya wanna go?
    Sound familiar?
  27. #22
    mburger's Avatar
    Punta Gorda FL
    Yup it does sound familiar.
    Mark
Clever Turn Signal
