Thread: Soft top, Whitby, missing Mounting Hardware
    Unconventional Builder Joee's Avatar
    Hatboro PA
    I bought this top top fabricate my own bimini top. Never got to it. You could make it a full top by purchasing the missing parts from Whitby, I have the instructions and full parts list
    ** SOLD **
    Roadster Mk3 5294, 302 Comp XE276HR cam, AFR 185 heads, 650 Quick fuel carb, Air Gap intake, T-5 3.55 gear Levy Upper & Lower Front and Rear control arms Purch Jan 2008 Tagged Mar 2012 Best ET 12.14 @113** SOLD 4/8/18 **
    YouTube Videos: Current performance - https://www.youtube.com/channel/UC7c...86xO3U4l4RtVMQ Older build - http://www.youtube.com/user/joeembery#p/u My Pics:
    http://s207.photobucket.com/user/Joe...?sort=6&page=1
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    You sure this is a Whitby top? It looks like an early FFR soft top. If it's a FFR top you have almost all the parts. Just need the
    ferrule that go into the body to mount the cross bar (Whitby sells a nice set of them with a rubber O ring to seal them against the body), the pins that go into the body (get them from boat shops), if it is a FFR top there will be two straps sewn into the top that wrap over the cross bar that you need to install a snap on the end of the straps, and if you don't have them the clamps that connect the front of the top to the windscreen support posts.
    Then if you want side windows, Whitby side curtains may work or while in England I visited the Europa Specialist Spares store and it's amazing the parts they have for the Cobra's including the hard frames for the side curtains. They will ship parts for you.
    I've been running a FFR soft top and it does help in the rain. It will keep you less wet. NOT dry just a lot less wet!
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
    Hatboro PA
    Ralph thanks for added info, I was under the impression the Whitby made the early tops for FFR (?).
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    This soft top came before the Whitby top. Now the basic soft tops from FFR, are the Whitby designed tops. Then there is the new premium soft top that I have... not yet... talked myself into purchasing one …. yet
    Ralph Button
    Hatboro PA
    Anybody want this as a top project?? It's in the way want to make room, make offer.
    Senior Member bil1024's Avatar
    NY
    PM sent
    Hatboro PA
    sold
