Thread: Rousch Supercharger for Coyote
    Jul 2017
    Has anyone put in a Roush Supercharger in their Coyote engine? I know the power steering has to be moved over a few inches. I had to make a plate to make it work. I would love to share information with anyone who has put one in or is in the process of getting one. So far i seem to be one of the few people putting one in.
    Are you putting that on a stock Coyote with 11:1 compression? I think if you order a supercharged Coyote from Ford racing it is set up as 9:1? Its been a long time since I looked at that so those numbers could be wrong. Just curious.
    looks great, btw.
    Jul 2017
    No. It is actually the low compression aluminator engine. 9.5:1
    I wanted to use pump gas. Should be a good strong engine. Im excited to get it up and running soon.
    I will show people what i did when i figure everything out. I was just hoping someone else had the same setup to make sure its all hooked up correctly.
    Maricopa AZ
    currently have one in the shop. If you email with specific questions I can shoot some pics for you.
    Jul 2017
    So I have a few questions. First off, there is no brake booster with the Roadster. Do I plug off all the vacuum hoses that would go to the brake booster? On the wire harness from ford racing there is an intercooler wire. Do i use this instead of the supplied relay they sent also for the 2017 mustang? trouble getting the air filter set up just right? I ended up using a 4 inch 45 degree bend to hook it all up. Just needing a little help if anyone knows anything. I did send you a message last week Gordon. hoping to hear back from someone.
    Heart of Dixie, Alabama
    I have Gen I Coyote and harness, it does have a wire in the harness labeled intercooler pump. Not for sure this is in the Gen II harness.
    Jul 2017
    I think i have it mostly wired up. He is what it looks like so far. Anyone have any thoughts on the oil separator? Are they a must for superchargers?IMG_1911.JPG
    If you see the amount of oil they catch, you would say yes.
    I have them on both of my supercharged cars. I have a JLT on a 13 Shelby and a home made one on a 99 Cobra with a KB supercharger.
  10. Thanks WIS89 thanked for this post
