Thanks Thanks:  11
Likes Likes:  81
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 129
Thread: Bobs 33 build
    Feb 2018
    E brake handle installed
    Feb 2018
    tranny fill, Oil fill, coolant and rear end
    Feb 2018
    Wiring start
    For the 302 block the oil pressure sending unit needs an extension so it clears filter
    Feb 2018
    Learning to shift
    Feb 2018
    Missed the exhaust install
    Feb 2018
    Ok ready to roll
    I have posted most of my steps for the last couple of months and probably missed some. Just happy to be making the progress I have and need to add that i am totaly enjoying this adventure.
    So go carting time has come, i hit a lot of hurdles on this day but did end up getting them resolved.
    started with electric fuel pump, i have never worked with one and assumed it should get to pressure and then shut of but the one I have for a carburetor engine does not shut off, apparently Ok but I will put a regulator with shut off down the road, any comments or ideas welcome.
    Next was my incorrect wiring of the starter, I have changed a few in the past but always just removed and wired up as I took off. So from wiring diagram i assume i needed to ground this and was wrong, a bit of research cleared this up.
    I had taken the distributor out to hook up coolant line fitting and now had this in wrong and had to redo, did have this figured but took time for a greenhorn like me.
    All stressed i did get it fired up
    Feb 2018
    I did a few small runs down the street.
    Ended up setting timing and adjusting electric choke and idle screw.
    Have an exhaust leak but left on vacation so can deal with that once back but should not be a big deal
  8. Likes shmelty liked this post
  9. #48
    Feb 2018
    Feb 2018
    My son went down the road and actually came back
  11. #50
    Jun 2018
    North Vancouver, BC, Canada
    Lookin and soundin great Bob!!!
  12. #51
    Gatineau, Quebec, canada
    Quote Originally Posted by Bgardner View Post
    Looks like your youtube account was disabled, may want to check it.
  13. #52
    Feb 2018
    Not sure whats up, I can see video from this site
    Is there any way to post video without youtube
  14. #53
    Jun 2018
    Whatever was wrong it seems to have corrected itself, I see the videos again....
  15. Thanks Bgardner thanked for this post
  16. #54
    looking good
  17. #55
    Feb 2018
    Body work started
    set body in place and measured every way possible. ended up with different size spacers in wheel well to frame area, without this body was hitting door mount.
    started with the trunk, curve of body and trunk don't match up so like others I put in some bracing. Pic showing original fit
  18. #56
    Feb 2018
    Body work started
  19. #57
    Feb 2018
    So I made a template and then cut plywood to fit shape
    I used plywood for stability and then made hardwood inserts where I will be bolting plywood to body
    I used rivnuts to bolt plywood to frame
    You can see the gap in pic below, I pulled the trunk into shape with ratchet straps
    used a caulking adhesive and bolted plywood to trunk
    happy with final fit and shape, trunk also lifts up a lot nicer with a more stable feel.
  20. Likes FF33rod, JOP33 liked this post
  21. #58
    Feb 2018
    Next up I will fiberglass these pieces
  22. Likes FF33rod liked this post
  23. #59
    May 2016
    North of sacramento Ca.
    No pics
  24. #60
    Jun 2018
    Quote Originally Posted by 1932 View Post
    No pics
    ??? Can't see Bob's pics? I do...
    Gen 1 '33 Hot Rod #1104
  25. #61
    May 2016
    All good
  26. #62
    Feb 2018
    So I did fiberglass and onto mounting trunk, unmounted sits perfect where I want it. very tough to line up with hinges and latch.
    Ran into trouble with drivers side hinge arm hitting gas tank, I have the FFR stock tank. NO room to move arm location (set mounting points welded) and tank only has 1 place to sit. I grinded the arm and I feel it will have sufficient strength, I will go back later and do the other side to match. For sure need a break from removing trunk lid again. Other unknown problem when trying to get to fit was when coming down trunk lid was hitting flange for weather striping, just grinded some away and was all good will do the entire opening for an even spacing.
    For the latch I needed to get FFR to send me a longer pin (same size as used for front hood). according to parts list and packaging the short one I received is for the trunk and the hood has a longer one so I used it and things worked. Latch is tough to line up and couldn't find anyone small enough to climb in to see what was happening when closing trunk LOL. not sure what others have done but after the fact was thinking maybe setting a live camera up to see would have worked better than the multiple open/close test
  27. Likes FF33rod liked this post
  28. #63
    Village Mills, Texas
    Don't put the trunk floor in until you finish the trunk lid and latch.
  29. #64
    Feb 2018
    Good advice
    I think it was the back panel that I struggled to get inside the trunk with body on so I put all the aluminum in with body off. Thinking the access holes would work but struggled with access through them.
  30. #65
    Nov 2019
    My grandson checking out how his ride is coming along. Told his mother he can take the 33 when he goes and gets his licence.
    Attachment 101224
    What's on the garage wall? Are those 1x4s grooved with some type of hook system? What is that, please? And yea, sweet ride!
  31. #66
    Feb 2018
    Slatwall
    It comes in 4 * 8 sheets and and just screws to the wall, lots of different hooks available.
    There are different brands around, in my trade we did use this product for retail stores to display their products.
    Here is a link to a supplier in Canada, some lumber yards cab also get this product.
    https://www.uline.ca/Product/Detail/...B&gclsrc=aw.ds
  32. #67
    Feb 2018
    installed windshield with some support to keep body shape and then later fit hardtop to body
    I notched a piece of L-shape aluminum and bent it to fit shape of underside of windshield, epoxied this in place under the windshield using the windshield studs. Then i epoxied a piece of flat stock to the L-shape to hold the piece to fit the curve. Now when I remove the windshield the body remains in the same shape without flexing.
  33. Likes FF33rod liked this post
  34. #68
    Feb 2018
    Doors done, faced similar problems as everyone else. Will be interesting when doing the power windows.
    Fit hood and engine side panels, For this I kept the grill as far forward as brackets would allow to start and was OK to keep it there.
    I did shave off all fiberglass as close as I could to the half round reveal on the engine side panels and was lucky enough not to need to cut these like others have.
    Trouble with the striker pin clearing the rad aluminum so needed to file some and make things fit.
  35. Likes FF33rod, shmelty, JimLev liked this post
  36. #69
    Feb 2018
    Not sure why some of my pics are showing and some are showing as attachments.
    Will try and work on it in next day or so.
  37. #70
    Feb 2018
    Got it figured
  38. #71
    Feb 2018
    To fasten the engine side covers to the body I glued and fiber glassed some blocks inside and then bolted these to the firewall. now I will not need to have an exposed fastner when hood open.
  39. Likes FF33rod liked this post
  40. #72
    Feb 2018
    I made the engine side covers removable, so i cut panel and fiber glassed blocks on each piece to bolt together when covers in place.
    To keep the front part of the engine side cover in place I fit some notched aluminum blocks to slide onto lip of front grill, Once i slide it in place it gets mounted to the nose cone and also held in place with headlights. As per side engine panel to firewall I will also not have any exposed fasteners here.
  41. Thanks FF33rod thanked for this post
  42. #73
    Feb 2018
    Pics of the engine side covers on and off
    Pic of possible vent to go on engine side covers, I have done short little runs up the street and find there is a lot of heat building up in engine compartment real quick. any feedback regarding must have ventilation or not.
  43. Likes FF33rod, AJT '33, Mrallsport32 liked this post
  44. #74
    Senior Member JOP33's Avatar
    Haslet, Texas
    Like your rear fender cuts!
  45. #75
    Feb 2018
    Thanks, not sure how many rocks/pebbles will be thrown but happy with the look of the shape.
    it was fun to copy shape to other side, when done I found out everything is not perfectly balanced but without taking measurements no one will know
  46. Likes FF33rod liked this post
  47. #76
    Feb 2018
    As per previous pics I do have my hardtop on and bolted in place. I will be having a body shop do all my final fit and finish, for the hardtop I will get them to set the curve to fit the body. some of you guys have done a great job with this on your builds.
    I did cut back the window openings, scribed and trimmed. was surprised and happy to see this little clean up made the car look even better.
    With the hard top I did spin 1 of the rivnuts, very frustrating getting bolt removed. Got lucky but potential problems could cause a lot of damage. Figured out using a clamp to compress the rivnut tool works well and gives a good feel of control.
  48. Likes FF33rod liked this post
  49. #77
    Feb 2018
    Made a walnut wood dash for gauges. started with a flat 5/16 thick piece of walnut and cut it shape of dash with 1/2 inch inset. scribed dash to get shape for form to shape walnut too. the dash curves in and out along with different shape on top and bottom.
    Made a steamer that would allow dash to fit then steamed walnut and clamped in form
  50. Likes FF33rod liked this post
  51. #78
    Feb 2018
    Made some aluminum fasteners to mount dash. works well with no bolting from back and stays tight, easy to remove and replace.
    I mounted the dash out from fiberglass 1/4 inch and put LED lights on the back to reflect off the fiberglass dash (will be painted same colour as body). needed to source a LED strip light that was able to go around the curved shape.
  52. Likes JOP33, HVACMAN liked this post
  53. #79
    Jun 2018
    Very cool Bob, looks fantastic!! You're making full use of your wood working skills.
    I gave up using that lame tool for the rivnuts and bought an Astro Pneumatic 1450 - makes the job so much easier...
  54. Thanks Bgardner thanked for this post
    Likes HVACMAN liked this post
  55. #80
    Haslet, Texas
    Like the backlighting!
  56. Thanks Bgardner thanked for this post
