Results 1 to 5 of 5
Thread: Rust Prevention
    Jun 2018
    Rust Prevention
    There are a few portions of the Mk4 frame (mainly the trunk/fuel tank area) that appear the internal portion of the steel tube is exposed (not welded into another support structure but left open). Is there any need to seal these off so humidity doesn't get into the frame tubes? Between 1) my high humidity summers and potential for road salts in the winter, and 2) my compulsion to protect every inch of exposed steel, I'm trying to get a handle on what is necessary and what is overkill.
    San Diego Ca 92106
    Eastwood has a internal chassis paint that makes this type of job easier.
    https://www.eastwood.com/eastwood-in...z-aerosol.html
    This is the stuff that i used; however, I wish I would have looked at the Eastwood products first.
    https://www.kbs-coatings.com/Cavity-Coater.html
    I've got Eastwood's tubing flare tool and it is crazy cool & super easy to use.
    Mar 2013
    Medway, MA
    you can use finisihing plugs to close some of the openings
    http://www.breezeautomotive.com/sear...inishing+plugs
    Jun 2018
    Great information Steve and Mark. Thank you!
