Results 1 to 2 of 2
Thread: Body Buck Available In DC Area
    Fairfax Station VA
    Like Chuck in Rochester, I'm done with my body buck. Free to a good home; I'm in Fairfax VA. Body profiles have been modified to best fit the MKIV Roadster.
    Truth In Advertising: The buck is glued & screwed together, so you'll either have to cut the legs off or bring a good-sized trailer.
    MK IV Roadster #8631
    Fairfax Station VA
    Last call. The buck is 84" wide x 94" long x 77" tall.
    If you wanted, you could cut the legs off to make it shorter, and/or cut the center section and just keep the body profiles.
    IMG_0957 by jhsitton, on Flickr
