0
0
Help! Beta builders or FFR.
What are these welded brackets inside the frame for? They are where I normally run my fuel lines on the 33. I have no manual so it is a PITA trying to get stuff done with the 33 manual even though there is a lot of differences. Any help would be appreciated. I am trying to get as much done as I can without the manual. Thanks, TW.
Think I figured them out,. I think they are for the running board brackets. Correct me if I am wrong.
Tom,
You are correct. Those are the mounts for the Running Board Supports.
