Results 1 to 7 of 7
Thread: Undercar Exhaust?
    Jan 2015
    Undercar Exhaust?
    Tried searching the forum, but could find nothing current.
    Is there ANY option to do an undercar exhaust with the MKIV Roadster?
    Thanks.
    JP
    Maricopa AZ
    Yes, but it needs to be custom fabricated
    Here is a source for some very low profile mufflers and low profile oval tubing options too.
    https://spintechmufflers.com/muffler...file-mufflers/
    https://spintechmufflers.com/exhaust-tubing/
    Good luck and hope you find your solution.
    mburger's Avatar
    Punta Gorda FL
    65 Cobra Dude (Henry) did under car exhaust on his MkIV. Perhaps he has info or pics.
    Mark
    San Diego Ca 92106
    Most of these threads I would imagine are on the other forum ,ffcars.
    https://www.google.com/search?q=unde...obile&ie=UTF-8
    Senior Member Duke's Avatar
    Taxachusetts
    Port Charlotte, FL
    JP,
    I did do undercar exhaust that exits just in front of the rear wheels. I used Spintech mufflers and oval tubing. It's expensive and you need special benders to bend them though. I wouldn't change a thing. I can send pics when I get back from vacation if you would like?
    Thx,
    Henry
