Results 1 to 5 of 5
Thread: Alignment shop recommendations
    Millis, MA
    Looking for an alignment shop in the metro west or eastern mass area. I went to a shop in medfield this morning got my sticker, but they said the alignment would be 2-4 hours at a shop rate of $187.50/hr. I declined. So I’m looking for someplace more reasonable. Thanks
    “Privateer”
    289 USRRC Chassis #9188 p/u 9/11/2017 Go kart 3/18/2018, road legal 6/16/2018
    Ford full roller 306 built by my son and me Holley Sniper EFI
    TKO600 2015 IRS 3:55. 17” FFR Hallibrand replicas, Power steering
    FFR Vintage instruments, Wipers and Heat/defrost
    Lots of parts and advice from Mike Forte & Mark Reynolds (Breeze Automotive)
    Senior Member Duke's Avatar
    Taxachusetts
    Jerry at EPE in Natick did my corner balance and alignment. Not cheap, but well worth it.
    Millis, MA
    What constitutes not cheap?
    “Privateer”
    #9160 BB767's Avatar
    Chehalis, WA
    Get one of these (or similar) and do it yourself. For the cost of one alignment you can have a lifetime of them for free! Remember, if you change your ride height for any reason, you will need a new alignment. If you hit a big pothole you may need a new alignment. If you want to fine tune the handling qualities to suit yourself, you can do it any time you want. If you can build the car you can certainly learn to use one of these. I have been very happy with the results of this model but there are others that work well too. You will also need to either purchase or make your own toe plates, very simple to use as well. Just my 2 cents worth.
    https://www.amazon.com/Camber-Caster...ment+gauge+kit
    MK4 - complete kit - Blueprint 427W - Holly Sniper EFI - TKO 600 .64 - 3.55 3 link - 17" Halibrands
    Taxachusetts
    Quote Originally Posted by chuckster View Post
    I don't recall exactly, but I think it was 6-800 or so with corner balancing. Don't quote me on that though.
