Greetings,
I think I'm over thinking things so I need a sanity check on the fuel pump wiring for my Holley Sniper EFI which uses its own wires for the fuel pump.
Page 14 of the Factory Five Wiring Harness instructions say the following: "If the EFI harness uses its own wires for the fuel pump, cut the small tan jumper wire close to the connector that it jumpers from and connect the fuel pump wire from the EFI harness onto the chassis harness wire. This will use the EFI computer to turn the relay on/off.
This part seems vague to me- "connect the fuel pump wire from the EFI harness onto the chassis harness wire. This will use the EFI computer to turn the relay on/off."
This mean splicing the wire from the EFI harness directly to the fuel pump wire in the Factory Five rear harness, right? I'm assuming that is the case because the Sniper EFI harness has its own relay preinstalled on its fuel pump wiring.
Thanks for the help.
