Does anyone have a part number or link to a 4.6L Non-A/C Power Steering Bracket? I am having a really hard time finding one!
My kit came with a non-AC bracket and pulley. Are you looking for the same sort of bracket to replace the power steering pump?
Mark IV -- 04 Mach1 Donor -- 4.6 DOHC -- TKO 600 -- 3:55 Gears -- 3 Link - Hydroboost PS & PB -- 13" PBR's Front & 11.65's Rear -- Cuesta Wiring -- Thompson Signals -- FFR Radiator, heater, wipers, and catalytic converters -- Metco DS safety loop -- Forte 7/8" front bar -- VPM 3/4" rear bar -- Champ road race pan -- Corbeau A4 Seats -- Nitto NT-05's on 17 x 9's.
I guess I don't know! On page 69 of my instruction book it says that in order to run PS I will need the mounting bracket from a Non-A/C car to move the PS unit up out of the way of the steering shaft. My kit isn't here for a few more days, so perhaps it is included based on your findings.
Page 69 is a tad confusing. What year is your donor? SOHC or DOHC? Will you be using power steering and/or air conditioning?
2002 SOHC Donor that came with A/C, planning on removing the A/C and keeping the power steering for the build.
If the AC compressor is tucked under the passenger side front of the engine, then the bracket that comes with the kit will eliminate the compressor. If the PS pump is tucked under th driver side front of the engine, then it can stay there and your all set.
That answers that, I think that I am all set. Thank you for your time.
Walt is absolutely correct, PS pump stays where it is (reservoir will have to move), AC compressor goes away and your kit will have a pulley to simulate the AC
Also with that set up you should not have to do the oil filter relocation.
I agree. I have the same engine (2002 4.6 SOHC) and the power steering pump is ok, I moved the PS reservoir a bit higher and added an elbow to one of the lines to move it further away from the steering shaft. Now the steering shaft goes in between the two lines coming off the bottom of the PS reservoir.
