I just pulled the trigger and ordered my Mk4 base roadster. My heart is pounding and I feel like yelling at the top of my lungs. The next order of business is a body buck. I live near Ithaca, NY and I was wondering if anyone, within 250 miles, has a buck to pass-on, loan, or sell? I can't wait to get started.
CONGRATS!!!! And dude... you ordered your kit... DO yell at the top of your lungs!!!
Gen3 Coupe - SOLD Arrival: 6/21/18 SOLD: 4/12/2019
Current Vehicle: 2014 SRT Viper (modded to the moon), 2022 TRX, 2014 RS6, E46 LS3 M3
Current Projects: Superlite/RCR GTR ***FOR SALE***
@madd_wrapps on IG or www.maddwrapps.com
I would just spend the $100 bucks to build it yourself. A few reasons
1. It will give you a project to work on while you wait!
2. I built a rollover type, that could be stored by rolling over the chassis.
3. Shelves, I made a great shelf that I stored many parts and tools during my build.
4. You have to go pick it up and haul it back.
5. I built it out of strand board and 2x4, got the castors from harbor freight for cheap.
6. Use drywal screws, they are cheap and allow you to take it apart easy if you need to.
Good Luck man, this will be the blast of your life.
Congrats!! I just hung by body from the garage ceiling using a couple of kayak hoists. I put a piece of wood between the front and the back of the cockpit to stop it from bowing but it's been up there fine since march.
Build 1: Mk4 Complete Kit #9312 Ordered 1/27/18, Delivered 3/24/18, CA SB100 Registered 9/11/19 - Gen 2 Coyote TKO600, IRS, Power Steering, Wilwood Brakes, 17" Halibrand Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering
If you do build your own body buck to roll over your chasis make sure it is wide enough to clear when you put your wheels/tires and side pipes on.
JR
"Doddmoore," Mitchell Moore on facebook, Follow Tonks347Cobra on Instagram
MK IV Complete kit, SB Ford 347, Holley Sniper EFI, TKO 500, Moser 8.8 Solid axle, Wilwoods, Power Steering
My Build Thread: Tonks347, The Baker's Build
Slow and steady wins the race.
Thanks for all of the support and encouragement. After browsing the digital manual I found the pattern for the body buck. Now I need to know the dimensions for the 2x4 that goes in the cockpit opening to prevent flex during body removal/installation. Thanx to Dan @ FFR for clarification on the order form.
I think the current thinking is that the Mk4 body doesn't need an anti-flex 2x4 strut during body removal. The new under-door sections are beefier than previous versions. If you watch the FF videos showing them removing the body, you'll see how much bend they can take without a problem. It's a little tense the first time you do it, then you realize you're not going to hurt anything.
Also, look through the forum for a new design of the rear body buck profile. It's not a big deal because virtually any support is enough for the body, but in my 2016 version of the manual, the rear body buck profile didn't match the car at all.
Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
Congratulations , if you think you are excited now wait till it is delivered, and the first start. Finally when you get it back from the painter. Please remember we are always here to help you blow thru your budget.
Doug
FFR 7995
347 SBF Prestige Mototsports, Moser 8.8 (3.31) 3 Link, TKO 600, Nitto 555s, 17" Halibrands, PS, AC, Heat, Color Redfire Pearl, with Wimbledon White Stripes
