Russ' Garage
Thanks Thanks:  33
Likes Likes:  3
Page 2 of 2 FirstFirst 12
Results 41 to 76 of 76
Thread: Meindl Mk IV Build
    Senior Member BadAsp427's Avatar
    Summerville, SC
    I think you should set the seats in the appropriate position, then get some support across the hood area and set up a 45" tv and have a "drive-in" movie night now and then... Just no eating or drinking in the roadster...
    Mk4 20th Anniversary #8690 ( #8 of 20 ) Purchased 8/18/18 Started 8/19/18
    Build Thread Click Here
  2. Thanks PeteMeindl thanked for this post
    Likes WIS89 liked this post
  3. #42
    May 2018
    Riverside CT USA
    Ha! I love it. The 'drive in' will be open this weekend!
  4. #43
    Dreaming.... Duck62's Avatar
    Sep 2018
    Aiken, SC
    Quote Originally Posted by PeteMeindl View Post
    I think we now have one of the best pieces of art i've seen in a living room in quite some time!
    Inventory is almost done and has gone well - thanks for the pointers, guys. We're just trying to iron out the coyote engine parts from ford as i think we might be missing a page or two of the packing list (and it's been a little harder for us to tell what the parts are there and whether they've already been installed in the engine...). But hopefully we will figure that out shortly.
    Here's the current state of car. Not fully disassembled yet but on our way.
    Now that is a mans man. I would be sleeping beside it if I evern tried that!
  5. #44
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    So we were thinking of storing it outside but then Sarah said, we use our living room barely even once a year so why don't we put it there? And so there it is!
    Give that incredible gal a big 'ol smootch for all of us!
    John D. - Minneapolis 'Burbs
    2018 Mk4 Roadster - #9365 Build Thread
  6. #45
    Mark Eaton's Avatar
    Oregon
    You definitely married the right girl
    MK4 #9130 , complete kit, arrived 8/10/2017.
  7. #46
    May 2018
    Riverside CT USA
    Sarah says thanks for the compliments! We are basically finished with inventory and have taken all the panels off the car. Here's how things look at time 0.
    Now time to start building! We're all excited.
  8. #47
    Junior Member Kool AC's Avatar
    Sep 2018
    Armada, Mich
    Congratulations, exiting times. Just curious, what is in the large Ford Performance box at the rear of the frame?
  9. #48
    May 2018
    Riverside CT USA
    Hi Kool AC, the Ford Performance box holds a bunch of engine accessaries that come with the Coyote package from factory five. Control pack, some sensors, hoses, etc...
  10. #49
    May 2018
    Riverside CT USA
    F panel installation
    Today we drilled the F panels, cleaned them off with acetone, sharkhided (or sharkhid?) them, drilled the chassis and learned to rivet them on the chassis. Felt great to get them on the car! That sharkhide is pretty strong stuff...
    Here's the left panel.
    And here's the right.
  11. #50
    Member SSNK4US's Avatar
    Bakersfield, CA
    O. M. G. !
    If everything seems under control, you're just not going fast enough....
  12. Thanks PeteMeindl thanked for this post
  13. #51
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    You have a great start Pete!
    It looks like Factory Five added the cutout at the top of the elephant ear tabs that Edward B suggests adding in his build thread. Some one is listening at FFR.
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018
    Serial #9158
  14. Thanks PeteMeindl thanked for this post
  15. #52
    May 2018
    Riverside CT USA
    Thanks, Yama-Bro! I'm really enjoying your build thread, by the way - thanks for the thorough documentation as I'm learning a lot from it!
  16. #53
    Jul 2012
    Kearney Nebraska
    Thanks! Glad to hear that you are getting some use from it.
    Serial #9158
  17. #54
    May 2018
    Riverside CT USA
    Front lower control arm question
    Hi guys,
    Our next step is installing the front lower control arms. Like i've noticed in a number of build threads, one of the brackets on the chassis that holds the lower control arm is a little too tight for the arm to fit in. From the threads, it sounds like the best thing to do is just bend the bracket out a little bit. What's the best way to do this in a controlled manner? Thanks for your helpful advice! And remember, you can safely assume i know nothing and won't be insulted by any overly simplistic answers. Thanks again for your help!
    Pete
  18. #55
    Summerville, SC
    Hi guys,
    Pete
    Probably one of the easiest is a short piece of threaded rod with a couple nuts on the inside and then just thread them outwards to the desired width. Of course I would suggest th use of some washers and a little lubrication to help prevent tearing up the powder coat too much. (wd40/30w, etc)
  19. Thanks PeteMeindl thanked for this post
  20. #56
    Aug 2017
    Minneapolis 'Burbs
    Another quick method is a BIG adjustable wrench. Lay some protective tape on the jaws, close around the frame tab, and give a little "tweak".
  21. Thanks PeteMeindl thanked for this post
  22. #57
    Senior Member cv2065's Avatar
    Dec 2017
    Hi guys,
    Pete
    Probably won’t be the last. I had to spread mine out on just about every fitting. No big deal. As has been said. Make yourself a spreader with threaded rod, some nuts (no nylocks) and some hardened washers (grade 8). Keep it handy as you’ll most likely need it again .
    MKIV Roadster - Complete Kit - Delivered 7/17/18
    Build Thread: https://thefactoryfiveforum.com/show...V-Build-Thread
  23. Thanks PeteMeindl thanked for this post
  24. #58
    Jul 2012
    Kearney Nebraska
    I did what fixit described. It worked perfect. Just don't get crazy with the bending.
    While you in this phase, I'd suggest putting some pre-lube on your bushings before doing the final assembly. Just to prevent squeaks when you start driving it. I didn't, wish I would have. Hopefully, the grease zerks will do what they are supposed to on mine.
    Serial #9158
  25. #59
    Kirkland, WA
    I think I used 5/8" threaded rod on my spreader.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, Roller: 12 Jan 2018
    Forte: 2016 Coyote & cover, alternator, engine controls, clutch kit, bellhousing, Moroso pan, TKO600, midshift, 3.55 axle, 190lph fuel pump, Spectre air inlet and filter. Breeze: battery forward and switch, fuel pressure regulator and braided hose, radiator shroud and mounts. Replicaparts: radiator panel, under dash panel, weathertight connectors.
  26. Thanks PeteMeindl thanked for this post
  27. #60
    May 2018
    Riverside CT USA
    Thanks a lot, guys - that's really helpful and clear. I appreciate it!
  28. #61
    For the control arms, I found that the real issue on mine was the bushing sleeve was slightly long. Even with the tabs bent outward they would only go 8/10ths of the way in. I bent the tabs back parallel and used by bench sander to take a slight amount off the bushing until it was just snug enough to be tapped in. I then put them back in the arms and tapped in to place. Each one fit quite snug without the fighting. I also found you may need to clean the inside of the mounting tabs as there was an occasional weld splatter on the inside that the bushings would get hung up on during install.
  29. Thanks PeteMeindl thanked for this post
  30. #62
    May 2018
    Riverside CT USA
    Grease, grease gun, and pre-lube recommendation
    Another naive question - does anyone have a recommendation for a grease gun and type of grease to use for all the grease fittings around the car? Yama-Bro, you mentioned a pre lube that would go on the portions of the control arms touching the brackets - any recommendations there?
    Thanks a lot, guys!
  31. #63
    Glen Burnie, MD
    Pre-lube should be the same thing you'll be greasing it with... some greases dont play well with others. I use Royal Purple Ultra Performance Synthetic grease. Great for everything.
    Plan: 427W-X, TKO600, Moser 3.55 rear.
    Delivered Feb 2017, first start Oct 22, 2017, first go-cart Mar 26, 2018
  32. Thanks PeteMeindl thanked for this post
  33. #64
    Dec 2017
    I second what Boyd said on the grease. I use the Royal Purple as well. I use a garden variety grease gun with flexible hose. Just remember that some of the grease gun tips will lock on to the grease fitting, and you’ll want to gently rock the grease gun tip back and forth to remove it from the fitting. Don’t get aggravated and pull on it or you could damage the fitting itself. Usually loosens up after a few uses.
  34. Thanks PeteMeindl thanked for this post
  35. #65
    May 2018
    Riverside CT USA
    Thanks a lot, Boyd and CV - i'll get some royal purple and we'll be good to go!
  36. #66
    May 2018
    Riverside CT USA
    Front lower control arms
    Hi guys! Today, we were able to install the front lower control arms. We haven't torqued them up yet but i think the installation went ok, thanks to all of your help. We used one washer on the rear bracket on each side. Special thanks to BadAsp, Fixit, CV, Yama-Bro and Initiator for the advice on how to make a spreader for the brackets. I needed this on the front left bracket and your ideas worked like a charm. Also, the bolts wouldn't fit through the bracket but a little filing away of the powder coating inside the hole, as many of you have suggested, quickly solved that problem. Here's a picture of one arm. Thanks for the help, guys!
  37. Likes BadAsp427 liked this post
  38. #67
    Kirkland, WA
    Getting there, buddy! Make a few more steps like this and all of a sudden you'll look at it and realize it's starting to look like a car!
  39. Thanks PeteMeindl thanked for this post
  40. #68
    May 2018
    Riverside CT USA
    Front upper control arms
    Just a quick update - got the front upper control arms reassembled this weekend per some great ideas from Yama-Bro, and got the ball joints in there. It definitely took some force on them while they were in the vice! I wasn't sure we were really going to get them in there but we eventually did. Also installed the grease inserts.
    Here's how they look - i think they are correctly configured but if you guys see anything that's wrong, please let me know - Thanks!
  41. #69
    May 2018
    Riverside CT USA
    front suspension assembly
    This week we've been working on assembling the front suspension. We attached the upper control arms, adjusted them to approximately the size mentioned in the manual, attached the spindles, and then the steering arms. We assembled the shocks with the springs and all but we didn't install them as it turns out we don't have the snap ring and it looked like it'd be a lot easier to deal with that while the shocks were off rather than on. So we'll be on hold for the shocks til we get those.
    We were able to get grease in all the grease inserts without exploding grease all over us - so a much better outcome than i had expected. We torqued down the bolts for the lower control arms to 110 ft lbs. We were then torquing down the bolts that connect the upper control arms to the frame. One bolt went fine but the second just kept turning and turning, without that much pressure. We tried to back it out to see what might be going on but it just kept spinning. So i guess maybe we stripped that somehow?
    A couple questions for you guys
    - Any thoughts on the best way to get that nut/bolt off? I know this is a super novice question...
    - Anything we probably did that created this problem that we should avoid doing in the future?
    - When getting a new bolt & nut to replace this one, do you guys generally recommend buying them from factory five (i'm not sure if they sell small little pieces of hardware like this) or do you just head to home depot/similar place and get a similar sized nut & bolt?
    Here's how things look right now on the right side:
    And on the left:
    Please let us know if you guys see anything that is wrong. I kept worrying about how on the upper control arms, there's a bolt in front of the ball joint on one side of the car and a bolt behind the ball joint on the other side of the car. But from what i can tell, maybe this is the way it's supposed to be? Thanks again!
  42. #70
    edwardb's Avatar
    Definitely sounds like your UCA mounting bolt is stripped. Those are pretty stout and should be able to handle the 100-110 ft lbs the manual describes. Sure your torque wrench is accurate? Otherwise, maybe one of the pieces is defective. I don't have any magic suggestions to get it off it it spins without the nut moving. Maybe grab the head of the bolt with some vicegrips and pull as you're turning it? You could unbolt the pivots on the control arm and get it out of the way so you have more leverage. Once there's a little separation, you could probably get a pry bar or screwdriver tip under the bolt or the nut and apply pressure as you're turning. Just be careful and don't gouge things up. Once it's apart, you can look at the parts and maybe see what they look like and if something failed. I'd call Factory Five and get replacements, explaining what you did and what you found. They will sell you basically anything that's in your kit. But if the part is defective, they should replace it without a charge.
    Very unlikely you'd find those specialized bolts at Home Depot. For the most part, the entire suspension has hardware that isn't real common, e.g. some is metric, flange heads, deformed lock nuts, large sizes, long lengths, etc. To be honest, I stay away from the big box stores for hardware on these builds. Some of it might be OK, and I know people use it. But I find the quality not that great. Our local Ace Hardware has a whole row of hardware that's all from Hillman. In general, I find the quality pretty decent. Better than the local HD or Menards, the two big box stores that are closest to me. If it's specialized, I generally order from McMaster. I haven't gotten a bad part from them. Some guys hook up with their local industrial suppliers, like Fastenal. Haven't tried that, but another option.
    From what I can see, your suspension is assembled properly. Totally normal that the upper control arm has the fixed part in the front on one side and on the back on the other. It works. And you're not the first or probably the last to ask about that.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
  43. Thanks PeteMeindl thanked for this post
  44. #71
    Aug 2017
    Minneapolis 'Burbs
    I'm going to throw out there that you've got the wrong nut on the UCA mounting bolt... It would take some serious effort to strip a bolt/nut of that size - and using hand-tools you're not going to strip or snap one unless it's obviously defective.
    I've had many a time where a metric or fractional nut will "appear" to thread on just fine and work, until you try to apply some torque. They're just close enough to spin on, but...
    Double check yourself on the fastener.
    As far as the UCA assembly (welded/fixed point vs. bolted point) the arms are welded up without Left or Right in mind. It really doesn't matter, as it's just geometry when they're installed. You crank the adjuster sleeves and they'll move the pivot point in the same way - if the fixed point is fore or aft.
  45. Thanks PeteMeindl thanked for this post
  46. #72
    May 2018
    Riverside CT USA
    Thanks a lot, EdwardB and John! I'll try your suggestion to get the nut off and see what might be going on. Thanks for the good advice in terms of where to get hardware, too - i'll go with ff or mcmaster then.
    Good idea to check the calibration on the torque wrench - i didn't know how to do that but just found a good video showing how to and it seems pretty straightforward. So i'll make sure that's ok too. And John, i'll check on whether i had the correct nut - I thought it was the right one but i certainly could have made a mistake. It wouldn't be the first and it won't be my last! Thanks for the once-over too on taking a look at the suspension.
    We may not be back at work on the car until next weekend but i'll let you guys know what we find out. Thanks again for the helpful advice! Have a good week!
  47. #73
    Mark Eaton's Avatar
    Oregon
    Be careful with those upper control arms and don't confuse the pivot shaft lock nut with the bolt that hold the arm to the frame!
    https://thefactoryfiveforum.com/show...l=1#post308193
  48. #74
    edwardb's Avatar
    Quote Originally Posted by Fixit View Post
    That's a very good possibility and one I didn't think of.
  49. #75
    Apr 2018
    Colgate, WI
    Great progress! Will it be possible to insert the shocks with the spindle installed of will some disassembly be required? I'm at about the same point on the fronts but was waiting for the shocks to arrive before installing the spindles.
    Mk4, IRS, (427 with EFI, T-56 MAG)
  50. #76
    edwardb's Avatar
    Quote Originally Posted by miller7448 View Post
    There's no issue installing the coilovers into a fully assembled suspension. Front or back. Would be an ongoing maintenance challenge if it weren't possible.
Levy Racing
