Thanks Thanks:  211
Likes Likes:  50
Page 5 of 14 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 543
Thread: Meindl Mk IV Build - Graduation
  1. #161
    Quote Originally Posted by PeteMeindl View Post
    We have a couple questions:
    - When looking at other build threads, we don't often see a frame extension sticking towards where the driver sits where you mount the pillow block that far back (as you see in the above picture). It looks like FF drilled holes for the pillow block at the far end of the bracket. Should we move the placement of the pillow block further towards the front of the car and drill some new holes or just keep it where it is? It just seems like most of the time people mount this pillow block further forward. Either way, we'll need to add a decent sized spacer to raise the pillow block enough to keep the steering shaft off of the frame - I think this is ok, right?
    - In the manual, it mentions to use threadlocker on the steering shaft but we weren't quite sure where - where do you guys use threadlocker on the steering shaft?
    A year or so ago (plus or minus) Factory Five redesigned the upper steering column mount to the longer version you have. This is the best picture I could find of the old version. Zoom in and you can see it. I'd be willing to bet that many build threads you're looking at have this older version, hence the confusion.
    Looks like the pictures in even the newest build manual are also still the older version. Although I haven't built with it, I've seen where others have reported the steering shaft hitting exactly like what's happening with yours. Many use the Russ Thompson turn signal assembly, which he has re-designed so it works with the new mount. Using it spaces the column up so it doesn't hit. If you're not using his mount, then add a spacer on each side of the bearing high enough to not interfere with the chassis.
    Probably they're talking about thread locker on the set screws on the upper and lower bearings. I wouldn't be in a hurry. You may end up with the steering shaft in and out a couple times before you're done. I always seem to.
    Edit: cv2065 posted a similar explanation at the same time as me. At least we agree.
  2. Thanks PeteMeindl thanked for this post
  3. #162
    May 2018
    Park City, Utah, USA
    Thanks, Paul! Yeah, that all makes sense and we'll take that path. One other interesting change that seems to have happened is that the accelerator bracket has changed such that the steering shaft now goes between the 2 accelerator attachment points on the left of the pedal assembly (the shaft now passes just under the top attachment point) rather than above both attachment points which is I think how it was in the past.
    Happy new year to you and thank you for all of your help!
  4. #163
    May 2018
    aluminum panels
    We've been doing a lot of drilling and cleco'ing lately - i can feel it in my arms after all that drilling! Here's a picture of the passenger side footbox:
    And the passenger side aluminum floor:
    Here's the inside of the footbox before we got all the panels in:
    We were wondering about a couple items:
    - for the outside panel of the passenger footbox, on the lower side of that panel along the edge of the panel that is parallel to the ground, do you guys rivet through that panel, the floor panel, and the round tube of the frame? Or just through the 2 aluminum panels?
    - It's ok to drill & rivet into the 2 main cylindrical tubes of the chassis, right? Such as for the aluminum floor.
    - At what point in the process do you guys think it's best to actually rivet all these footbox panels?
    Thanks for any advice you guys have!
  5. #164
    Looking good.
    Regarding the foot box and rivets, I’d try to just rivet the panels together. If you need to run some into the 2” tube it’s not a problem. I didn’t rivet into the main tubes for the floors but many do from what I have seen.
    I’d postpone riveting panels together until you can’t go any further. It’s nice to be able to take it apart if you have to get to something. When the panels are loose you can reach through the frame. Once the rivets are in you are going under and over. That’s when I understood why lifts were so popular.
  6. Thanks PeteMeindl thanked for this post
  7. #165
    Agree with Steve's comments. Couple more. See from your pics your panels are all still raw, including the ink marking. Are you planning to finish them in some way? Paint, powder coat, Sharkhide, whatever? If so, you want to do that after drilling and fitting, but before permanently mounting them. Also, I'd recommend after drilling that you take the time to clean up the drilled holes. I see a lot of burrs and flash around your holes. That's going to get in the way of setting the rivets properly and just generally needs to be cleaned up before whatever finish you do. You can use a deburring tool, a countersink bit, or I use a large nice sharp 5/8-inch drill bit and just twist it in the hole by hand. Cleans them right up.
  8. Thanks PeteMeindl thanked for this post
  9. #166
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    Don't know if you have compressed air available, but a pnuematic riveter will fast become your new best friend.
    John D. - Minneapolis 'Burbs
  10. #167
    ...See from your pics your panels are all still raw, including the ink marking. Are you planning to finish them in some way? Paint, powder coat, Sharkhide, whatever? If so, you want to do that after drilling and fitting, but before permanently mounting them...
    Just adding to Paul's comment...if you intend to leave them raw as many do take acetone or lacquer thinner and remove the ink markings ASAP. A thin layer of oxidation begins to build on the surface as soon as the aluminum sheets are manufactured but will not occur (at least not to the same level) over the ink---if you wait to clean the ink off the layer will be even heavier on the non-inked area and although the black markings will be gone you'll still see the less oxidized "shadow" of where it was.
  11. Thanks PeteMeindl thanked for this post
  12. #168
    May 2018
    Thanks, Straversi! Sounds good - I'll go that route.
  13. #169
    May 2018
    Thanks, Paul! What we've done so far before permanently mounting the panels (for the few that we've riveted) has been to acetone them to get rid of the markings and then sharkhiding them. We'll do that with these panels too before we mount them for good. Thanks for the good idea around deburring the holes - i like your 5/8 drill bit idea, nice and simple and gets the job done! We'll do that to clean it up!
  14. #170
    May 2018
    Thanks, Jeff! I've noticed that shadow on the previous panels we've acetoned and sharkhided and didn't realize what the cause was - now I do. Thanks a lot!
  15. #171
    May 2018
    Starting fuel system
    Thanks for all the good advice on the panels, guys! One final question on the panels before we move on - is it ok if some panels rise up a little past the frame? For instance here's a picture of the panel going up the vertical side of the transmission/driveshaft tunnel on the passenger side and you can see the panel extends beyond the frame. Is this ok or do you guys recommend trying to cut this down? Thanks!
    We're on to the fuel system now! Something i'm a little unsure about... We've put the vent and gasket into the fuel tank and are now looking at the fuel pickup. In the ff instructions, it says to drill out the 2 ends of the fuel pickup. The instructions, pictured below, show that you should use the exact same size drill bits to drill out each of the pickup lines - but they are quite different sizes. Is this right? Or should i use smaller drill bits for the smaller pickup.
    Here are the instructions:
    Here's a picture of the 2 lines:
    Thanks a lot! Have a good weekend, everybody!
  16. #172
    For those bent floor pieces that are extending above the top of the transmission tunnel, no you don't want that extra material there. It will prevent the transmission tunnel cover top from mounting properly against the chassis tubes. Looks like you already have it drilled and cleco'd. I've noticed they may extend slightly and need a little trimming. But not that much. I've found you need to push the corner down at the floor level pretty firmly to get them to go down all or most of the way. Maybe try that and see if they'll go down more. Otherwise, I'd trim them. But as a last resort. My usual advice regarding the aluminum panels is they're well proven and precisely laser cut. If something doesn't fit right, check the assembly, proper overlap, etc. before cutting metal. Almost always not required. My main experience with occasional trimming (just a little...) is to clear welds so they sit flat.
  17. Thanks PeteMeindl thanked for this post
  18. #173
    May 2018
    Thanks, Paul! We will try to push that panel down further and see if we can get it to line up. What you said makes a lot of sense.
    Anyone have any thoughts on the drill bits for widening out those fuel intakes? Maybe it's not too big a deal what size you use?
    Thanks, guys - hope you all are having a good weekend!
  19. #174
    May 2018
    Fuel Tank and Rear Brake Install
    Hey guys, Pete's son Jamie here. We've been working on the installing the rear brakes and the fuel tank and have run into a couple of issues. For the rear brakes, it seems that part of the brake caliper is rubbing on the rotor. Could putting in the brake fluid fix this issue? Also with the rear brakes, the supplied bolts seem to be too long and if fully tightened would come close to hitting the rotor. Is this normal or should we use different hardware? Any advice would be greatly appreciated.
    I know it's hard to see in this picture, but the part is not the only thing touching the rotor. Also, the mounting hardware is not fully tightened and would come close to the rotor if it was.
    This is the part of the caliper that is hitting the rotor.
    Next, we began work on the fuel tank and finished installing the fuel level sender, pickup, and filler tube. However, while trying to put it onto the chassis, we could not get the straps to fit around and attach onto the hardware. On both sides, we are close to attaching it but cannot quite get there.
    Driver side strap:
    Passenger side strap:
    Has anyone else had a similar issue? We were thinking that we get some longer bolts to attach it but wanted to see if anyone had a different idea. Again, thanks so much for all the help we have received. Hope everyone has a great weekend.
  20. #175
    BadAsp427's Avatar
    Greeneville, TN
    I'll address the fuel tank straps... It's not uncommon for the bolts provided to be just barely long enough... I would suggest swapping them out with some longer stainless steel ones. Those original ones will rust pretty quickly anyway.
    Also, just an observation, I see the chrome rear end cover. Many people believe that the chrome covers traps a lot of heat internally. They would also suggest putting on a cast aluminum cover to help with that heat. I'm sure that there is some merit to this, but under normal street driving, I'm not sure it is a big issue. Just an observation.
  21. Thanks PeteMeindl thanked for this post
  22. #176
    I see lots of comments on multiple threads about using stainless hardware. I use my share too... But two words of caution just in case. (1) The normal hardware store variety SS hardware isn't particularly strong. Likely not even as strong as average steel grade 5 hardware. Often not an issue, but just be aware. There's specialty stuff out there that's much stronger at places like Fastenal, McMaster, etc. But it's not cheap. (2) Get in the habit of using a dab of anti-seize lubricant when assembling with SS hardware. It has a bad habit of occasionally galling and then locking in place. At that point nearly impossible to get apart without destroying something. Usually at the worst possible moment. Ask me how I know.
  23. Thanks PeteMeindl thanked for this post
  24. #177
    Minneapolis 'Burbs
    Can't comment on the brake caliper interference...
    Gas Tank:
    As stated the bolts are just barely long enough to catch the nut - if at all. I replaced mine with standard grade 5 zinc coated hex bolts. (What is this affinity for socket head Allen bolts??)
    I went with either 1/4 or 1/2 inch longer (whatever was available). Trying to get an Allen wrench into the socket after a few months of road crud isn't fun.
    Don't bother with stainless. Nobody's gonna see it, they're not strong, and the 54 year old raw steel bolts on my El Camino's tank straps haven't rusted away yet - and it spent the 1st four decades of it's life as a daily.
  25. Thanks PeteMeindl thanked for this post
  26. #178
    May 2018
    Thanks, BadAsp, Paul, and John! We will get some longer bolts and that should solve our fuel tank issue. Looking forward to getting that installed!
  27. #179
    May 2018
    Potential solution for rear brake issue
    We are hoping we may have come up with a solution to our rear brake issue. As we mentioned, right now when we put the bolts in to connect the rear brakes to the bracket on the rear axle, the bolts are just a bit too long (maybe a mm or two) and they can come in contact with the rotors (as well as a center part of the brake itself, mentioned in a previous post). See in the picture below:
    Our potential solution is to put some washers in between the two brackets from the axle, pushing the upper bracket plate in the picture above to the left and thus moving the brake to the left a mm or 2 and that, i hope, will keep the rotor from coming in contact with the bolts and center part of the brake. I think that will help out - let me know if you think this is a bad idea. Thanks, guys!
  28. #180
    Minneapolis 'Burbs
    Don't know if this will work or not (without parts in hand/looking at it), but it costs nothing but a little time...
    I played around with your pic on a photoediting program and moved the parts around, and this may solve your problem. (I didn't save the "moving around" pic, but the overlay setup of the new configuration seemed to solve your problem). And now that I think about it, I think had to do this when I put discs on the rear of my El Camino.
    Now if this idea will require serious trimming/grinding/modifying the brackets don't do it. If it's just a little shave to clear a weld bead or something it's your call... but just jigging this up may reveal it's the solution.
    Flip the orientation of the brackets. Move the axle flange bracket to the inboard/inside surface of the axle flange, and mount the caliper/caliper bracket to the outboard/outside surface of the axle flange bracket. They'll still be in the same plane, but I think you'll gain that 1/16" clearance your looking for.
  29. Thanks PeteMeindl thanked for this post
  30. #181
    May 2018
    Ha - good thinking, John! I have to say I'm very grateful that you took the time to play around with this in a photo-editor to try to solve my problem - you go above and beyond the call of duty! Thank you.
  31. #182
    May 2018
    Installing the fuel tank
    Today we got some longer bolts for the fuel tank straps and installed the fuel tank. We then got the fuel filter and riveted that to the frame and connected it to the feul tank. Here are a couple shots:
    The entire tank:
    Looking at the connection to the fuel filter:
    We also put in Jeff Kleiner's quick jack mod - great idea Jeff! Thanks.
    Now on to the fuel lines!
  32. #183
    May 2018
    Thinking about fuel lines
    We've been mapping out where to run the fuel lines and wanted to see what you guys thought of our plan. First off, we have 2 segments of fuel line (each 5 ft). We don't have a flaring tool thus I think we either have to use 5 ft or a full 10 ft of line. From laying things out, it seems like we could use just one 5 ft segment and run the line starting just above the main 4 inch chassis tube in the rear, run it towards the front along the outside of the chassis tube, and then curve it up to the engine bay. This means we'd use the nylon hose provide to run from the fuel filter in the rear, rivet it into the frame along the vertical arm coming out above the 4 inch tube at the rear of the car, and meeting the hard line where the red circle is below.
    We'd basically do the same route for both the in and out bound lines.
    Does that seem reasonable to you guys? Thanks for any thoughts!
  33. Likes GoDadGo liked this post
  34. #184
    BadAsp427's Avatar
    Greeneville, TN
    It's all looking good... Question, where is your fuel pump going to be?
  35. Thanks PeteMeindl thanked for this post
  36. #185
    May 2018
    Ha - great question, BadAsp! You really helped us out here - we had inserted the fuel pick-up that came with the ff kit - and totally didn't realize that a separate fuel pickup (this one with an in-tank fuel pump) was also packed up with our coyote kit! Your question prompted us to realize this!! So thank you! Time to go replace that pickup.
    We have a fuel pump question we'll post in a minute...
    Thanks, again!
  37. #186
    May 2018
    fuel pick up question
    Thanks again, BadAsp, for asking about the fuel pump. We're now trying to put together the in-tank fuel pump and it looks like we need to do some crimping. Here's a picture of the order i think these parts come together:
    So i think we should strip those wires and connect them with a crimper. I've read that for automotive purposes, we might want to use a special crimping tool as a regular one isn't adequate. Is this true? Or does a regular crimper work.
    If we need a special crimping tool, does anyone have a recommendation for a good tool?
  38. #187
    Parker, CO
    Pete,
    When these things are assembled, the wire lengths are pretty short. Is there any way to just re-pin that connector that plugs into the pump? Or better yet, with the wires attached to the hanger plug directly to the pump with the connectors that are already crimped to them? That way you wouldn't need to crimp anything and the wire lengths would be no longer than you actually need. Just a thought.
    As for a crimper recommendation, here is what I have: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It works great and can do several different types of connectors.
  39. Thanks PeteMeindl thanked for this post
  40. #188
    FF6602's Avatar
    Nov 2018
    State College, PA
    So cool to have the body in the living room! What a gal! You better keep her! Good luck with your build - sounds like you are off to a great start.
    Craig
    10/2018 -- acquired Mk3.1 #6602 which was an unfinished project in go-kart stage; 9/2019 -- completed car enough to drive locally and compete in autocross events; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; Tremec 3550; 3.51 rear diff; lots of Breeze pieces; 2021 -- XP Champion in Central PA Region - SCCA Autocross Series; 2022 - installed windshield and registered in PA; my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
    6/2022 -- acquired Mk3 #1004; finished build; 347 stroker w/ Holley 560 carb SOLD
  41. Thanks PeteMeindl thanked for this post
  42. #189
    Kirkland, WA
    Pete - If you're using the F5-supplied fuel lines, be aware that you can get compatible pre-made lines in a variety of lengths from most auto parts stores. I used one of the long ones from F5, but then a shorter version from Action Auto Parts to get the overall length I wanted. They're pre-flared with fittings. just check the flared ends before you pay for them - I found a couple with damage that probably wouldn't have sealed well.
  43. Thanks PeteMeindl thanked for this post
  44. #190
    May 2018
    Pete,
    Thanks, Dave! That's a good idea - I'll see if i can do that.
  45. #191
    May 2018
    Quote Originally Posted by initiator View Post
    Good point, Initiator. Yeah, getting some shorter lines could help me out and avoid the decision of whether to add a whole 5 ft section or not. I'll be sure to check the flared ends too. Thanks for the advice!
  46. #192
    May 2018
    Starting the fuel lines
    We made our first baby steps to actually running the fuel lines today. We mapped out the path for the fuel intake line and reminded ourselves to make sure that the attachment fixtures were at the end of the line before we bent anything. Then we bent our first line - It worked great and in our excitement, we realized we forgot to do what we just reminded ourselves to do.... I guess now we have a fuel line to practice on!
    Then we taped the fixtures to the ends of the lines so we wouldn't forget again... We tried on the second fuel line and this time I think things worked ok. Here's how things look in the rear:
    And the front:
    We also drilled a couple holes and started mounting the line, although we've only done 2 so far as we aren't really succeeding in getting the clips to lie flush with the chassis. So we wanted to get your advice on this and one other issue:
    Question 1:
    When using those rubber insulated clips to attach the fuel line to the chassis, we just don't seem to be able to get the two ends of clips to lie flush with the chassis - we're thinking maybe these clips work better for the 1/4 inch line and we might buy some slightly bigger ones for the 5/16 inch line. Has anyone else had this issue and come up with a good resolution?
    Question 2:
    We got the fuel pump wires connected to the wires on the fuel pickup and we were thinking of putting some heat shrink around the connection. I'm completely naive but the exposed connection being submerged in fuel makes me feel a little worried. I also like the heat shrink idea as it'll help make sure these connections don't ever come undone. Here's a pic of the connection:
    So the questions are: 1) is putting heat shrink on just a silly, totally unnecessary thing to do? 2) if it's not a bad idea, is just regular heat shrink ok, or will the fuel corrode it away? and 3) if we should get special heat shrink, does anyone have a kind they like? We thought Raychem DR-25 would do the trick, but then we talked to someone at an autoparts store who said that wouldn't work in a fuel tank and that viton heat shrink was the way to go. Not easy to find that either. Any thoughts, guys? Thank you! Hope you're all doing well.
  47. #193
    Tybee Island, GA
    We've all done that
    Good Solution
    Question 1:
    I ordered these clamps for my 5/16" steel fuel lines. I used a 3/16" rivet to hold in place too. I probably have some left you can have.
    ME TOO. I don't recall any wires exposed like that in my stock fuel pump assy.
    Videos are at: YouTube Videos
  48. Thanks PeteMeindl thanked for this post
  49. #194
    Kirkland, WA
    Quote Originally Posted by DadofThree View Post
    We've all done that
    Too right. Usually only once, though.
    I also wasn't happy with the provided clips and found some insulated stainless ones - probably exactly the same ones as Dave but from Summit Racing.
  50. Thanks PeteMeindl thanked for this post
  51. #195
    Question 2:
    Yes, I think it's a good idea to put heat shrink around that connection. To seal it up, protect it, and make sure it doesn't come apart. Not a place you want to be having problems. But you can't use typical off-the-shelf heat shrink. Nylon or olefin are the most common, and it won't stand up to gasoline. Put some in a jar of gasoline overnight and see what happens. I'm not familiar with Raychem DR-25. When I researched this, I ended up using Molex Perma-Seal connectors. The Molex literature specifically lists gasoline as one of the chemicals it's resistant to. Related to this, I'm not sure I'd use those kind of AMP 1/4-inch blade style connectors. I recall they're rated at 15 amps, depending of course on the wire they're attached to. Your fuel pump will probably be one of your higher current draws. Plus the plastic on those crimping versions probably isn't rated to be in gasoline. I'd recommend a butt type connector like you pictured previously. Which leads me to recommending Molex Perma-Seal butt connectors. They're pretty widely available. I got mine from DelCity.net. A good source for electrical stuff in general in case you haven't discovered it yet. These if your wires are the same size: https://www.delcity.net/store/Perma!...12022.h_812023. These if they're different and you need a step-down connector (what I used): https://www.delcity.net/store/Perma!...12028.h_812029. Others may have other suggestions based on their experience. But bottom line you need something specifically made to be immersed in gasoline.
  52. Thanks PeteMeindl thanked for this post
  53. #196
    May 2018
    We've all done that
    Good Solution
    Thanks, Dave! Very kind of you to offer up some of your clamps - i bought some yesterday just like yours actually so i think we're good to go. Thanks!
  54. #197
    May 2018
    Thanks a lot, Paul! That's really helpful - we'll look at getting some of those connecters and make sure that we have versions of everything that can be immersed in gasoline. This is great.
  55. #198
    May 2018
    Installing fuel lines
    Thanks for all of the advice, guys. I think we've made some progress and now have the fuel lines installed. Here's a look at where things stand:
    Starting at the fuel tank:
    Moving down to the main tube of the chassis:
    Running along the main tube:
    Finally, into the engine bay:
    We then installed the charcoal canister:
    And attached the flexible brake lines to the front brakes:
    Next step is installing the brake reservoir which is underway. Hopefully we'll get that done next weekend. Hope everyone's doing well and enjoy the long weekend!
  56. Likes Mark Eaton liked this post
  57. #199
    Senior Member cv2065's Avatar
    Loookng good! You’ve gotten a lot accomplished!
  58. Thanks PeteMeindl thanked for this post
  59. #200
    Kirkland, WA
    Do you have your wheels and tires yet? I had to mess with the front brake flex lines in order to avoid rubbing the tire when the wheels turn side-to-side. Eventually went with a 90-degree fitting (pointed down) right at the chassis end of each line that solved it. That trick came from this forum.
