211
50
Originally Posted by
edwardb
Short of an actual official calibration lab, overkill in our builds IMO, I'd check your torque wrench against another known good torque wrench. Even though the physics can be calculated, I personally wouldn't try to calculate and use weights, etc. Just not something you want to get wrong. Another possibility is a device like this one that I've found are reasonably accurate and can be used to check your torque wrench(s). You clamp one end in a vise and put your torque wrench in the other for a good sanity check. I have a different brand, but this one from H-F is very similar and not very expensive:
https://www.harborfreight.com/12-in-...ter-63917.html. Also can be used to convert a regular wrench into a torque wrench.
Thank you, Paul! That's great to know and now i won't be trying to rig up that manual torque calibrator anymore - glad to cross that off of my list of to dos! I'll go ahead and buy that torque adapter you mentioned - thanks for the good suggestions, as always!
