Good idea, Initiator - we do have wheels and tires but we haven't put them on yet. We'll check that out and see what the clearance is on the brake lines. Thanks a lot!Do you have your wheels and tires yet? I had to mess with the front brake flex lines in order to avoid rubbing the tire when the wheels turn side-to-side. Eventually went with a 90-degree fitting (pointed down) right at the chassis end of each line that solved it. That trick came from this forum.
