Russ' Garage
Results 1 to 14 of 14
Thread: Just some engine updates
    Northern VA
    Not sure if everyone was aware, but after 1400 miles in gel coat, the motor had to come out. Here are some pictures of the new (junkyard shortblock) going together. I measured out the cylinders, they were good. So new rings and bearings went in. Kept my B 303 cam but upgraded to trick flow 170s with 58cc Chambers.
    All thatís left now is intake, oil pan (went with Gordon levy pan), roller rockers, and then we are ready to light this candle. Should be in the car between this weekend and next.
    2A58E119-C616-4F6B-953B-C8D69E6ED15C.jpg2CD35A2E-57F8-480E-B28B-588E4D073A1C.jpg0D350873-9AE9-4505-BED9-7986D16D020C.jpegFD709C12-5AD5-45D1-A6E8-831FA1E0C829.jpg
    Good Luck Mr. Scott!
    A Miracle Worker I'm Sure You Are!
    https://youtu.be/t9SVhg6ZENw
    Northern VA
    Lol Steve where do you get this stuff. I’m more of a close your eyes and hope it works worker lol
    Stafford Virginia
    Looking good Scott, can't wait to see second first start!
    JR
    MK4 complete kit #9059 ordered 1/19/17 delivered 3/23/17, 2015 IRS, Fortes/DART347,TKO 600, hyd clutch, P/S, 12.88 wilwood brakes front and rear, high back kirkey seats, heater/defrost and vintage gauges
    First start and go-cart 4/11/18
    Northern VA
    Quote Originally Posted by jrcuz View Post
    JR
    I’ll be sure to record it... again
    Senior Member RJD's Avatar
    Northern, VA
    Glad things are progressing well. Can't wait to hear that you're motoring once again.
    MKIV complete kit w/powder coating and cut outs, serial #9189 delivered 10/10/17, first start - 10/5/18, Blueprint 306 w/Holley Sniper EFI, TKO 600, power steering, Breeze fan shroud, trunk cubby, & engine compartment battery kit, CNC brake reservoirs, RT turn signal & gas pedal, mechanical throttle linkage, GASN side pipes, drop trunk, dual chrome roll bars, vintage gauges, vinyl dash w/ glove box, custom center console and cup holders.
    May 2016
    Looking great, I hand built my 347 and have extensive experience with the 5.0HO. Great work my friend. My 5.0HO with 170cc heads made 290 wheel horsepower with the trick flow top end kit and a tfs stage 1 cam. Its a great setup. You are probably going to see 250 wheel horsepower with that setup. YOu will also have tons of torque. Great work!
    Northern VA
    Thanks! Question, what dyno was that on? 250 would be pretty low for this set up
    May 2016
    I hope you make more but the tiny b cam is holding your combo back. It was on a SAE setting on a dynamite chassis dyno.
    May 2016
    Read on down. They talk about our two combo dyno runs.
    http://www.allfordmustangs.com/forum.../250658?page=1
  11. Thanks scottiec thanked for this post
  12. #11
    Northern VA
    Yeah I have read that one before. I had GT40ps with the last motor. I was really on the fence about buying a new cam, but I decided to stick with the budget. I was surprised with this article though. The only difference in it is the fact that they are using a boss block and a 750cfm carb. Mine is a 600cfm. https://www.google.com/amp/s/www.hot...that-work/amp/
  13. #12
    May 2016
    I find that they inflate numbers on that site as well sometimes. Guys with my same combo were saying they made 310 to 330 and in reality it was 290 real world.
  14. #13
    Northern VA
    interesting to hear, and good to know. I'll keep you posted dude
  15. #14
    May 2016
    You won't be disappointed. I promise that our little car with some 300+ lb torque that you have will be awesome.
Lodestone Billetworks
