Fuel Safe Systems
Results 1 to 2 of 2
Thread: Which McLeod twin disk clutch to order for my tko600/coyote
    Jan 2018
    Hello all, I'm in the market to buy a twin disk clutch for my TKO600/tremec aluminum bell housing/coyote engine/stock coyote flywheel. I was wondering if anyone knows the correct part number for the mcleod twin disk rst clutch that will work with my setup. thanks in advance
    Grand Rapids, MI
    Call McLeod, their tech support is awesome. Also if you get the original street twin clutch (1,200 hp rated) it comes with a flywheel, where the RXT doesnít. Iím running one on my 650 hp 461 Windsor. Great clutch with a good pedal feel for just under $1000 for the whole set up.
Clever Turn Signal
