Results 1 to 17 of 17
Thread: look like the rear end pumpkin is to close PROBLEM SOLVED
    herb fraser's Avatar
    take a look at these pic , it looks to me that the cross member is much to close to the pumpkin< not sure what to do, Herb
    After a week of scratching my head clearance problem solved see pic, The axle is a rebuilt alxe and the original owner welded on shackle extensions of almost 5 inches , So all I need to do is cut off the extensions and use the original shackle hole ,
    Jan 2018
    Twin Cities, MN
    I looks like your lower control arms are correct. Where are you in the suspension travel? Full Droop?
    I have the moser rear end and it has a much less pronounced diff cover.
    I just went and checked mine and it looks fine.
    Here's how you test - get 2 ratchet straps. Warp one around each side of the axel and the top tube of the frame where the bed will sit (there's a nice 2"x2" tube there.
    Ratchet until your suspension is bottomed out - then you know.
    thanks I will give it a try
    I ordered a new steel cover as the one on there is cast and sticks out to far, thanks for the help Tom and Stillwater35, Herb
    Stillwater 35 I don't know your name
    Jan 2018
    Twin Cities, MN
    Quote Originally Posted by herb fraser View Post
    Jeff - nice to meet you.
    Rotonda West Florida
    This depresses me. I just bought this weekend, and will take delivery by Friday of a G2 Aluminum cover. The cheap shiny Moser one, lacks a drain and fill plug. Bummer.
    Quote Originally Posted by KenWilkinson View Post
    still not sure if that is going to solve the issue , I will keep you posted , Herb
    Jan 2018
    Twin Cities, MN
    The moser has a fill plug. On the passenger side just rearward of the pinion.
    It does not have a drain plug - gotta pop the cover.
    Mar 2018
    I have the Moser stud girdle cover just like that for mine but also the stock style one just in case. On the S197 Mustangs, you have to relocate the panhard to clear that cover. I was assuming that it wasn't likely going to fit and it looks like you're having the same issue.
    Yes I am but I think the. Easy answer is to just change the cover
    I got my G2 cover today. It looks like it could fit in the same space. See photos. I got it from Summit for $129.
    https://photos.app.goo.gl/nKjoMLNs2pRRUg9Q7
    and
    https://photos.app.goo.gl/HdHhS3L97TvPXQAg9
    Wont know unless I try. Still waiting on parts.
    Bourne-Cape Cod, MA
    and
    That cover will work, I have a pickup completed with miles on it with that cover on it.
    FFinisher/AKA RE63
    got the new cover today but it still looks like it will hit not sure what I am doing wrong .will call tony and see what he says, Herb
    wallace18's Avatar
    Trenton, Florida
    Herb. I backed off on my spring perch's all the way and lowered the truck down. It will only hit if the suspension totally is collapsed. I personally are not worried. I doubt it would ever come to that.
    Mar 2018
    Herb, those are traction brackets, very common on S197 cars. It points the control arm at a more downward angle to help hit the tire harder when launching at the drag strip.
    Quote Originally Posted by Mark Gearhart View Post
    Thanks now I know , I was thinking they were used l in the day like ladder bars were used so same effect !
    did they come standard or owner applied
