Results 1 to 23 of 23
Thread: Drive shaft safety Loop Recommendation
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    I'm looking for a recommendation for a drive shaft safety loop for a MKIV w/ a TKO-600.
    Any suggestions would be appreciated.
    Sep 2015
    Beachside
    I went with the Metco loop. Good quality, bolt on, easy installation. I have the 600 as well. I think they run these in batches when there is enough interest.
    FFR #8833 289 FIA 3-link
    Santa Clarita, CA.
    metco here as well. Quick easy install.
    http://www.metcomotorsports.com/prod...p?prod=MDL2500
    Raleigh NC, OIB NC
    +3 Think you will find a lot of the guys are using them.
    Kevin
    MKIV #8234
    IMO: pretty much all of the aftermarket loops are too large to properly contain the very short drive shaft on a cobra, especially an IRS car. I went custom fabricated for this reason.
    This is the kit that I have yet to install which will require a little fabrication work.
    https://www.summitracing.com/parts/aaf-all69004
    Fairfax Station VA
    Metco here as well. Note that if you've got a spacer under the tail of the transmission it may require you to put spacers between the hoop and the frame. You'll also need longer bolts. The picture below is for my T5, but you get the idea.
    IMG_3369 by jhsitton, on Flickr
    MK IV Roadster #8631
    Mar 2017
    Thanks all.
    I thought about Metco, but assumed they no longer carry the item
    I just left a message with them to see if they have any plans to re-stock.
    Also have a message into Forte to see where he is at with his new loop.
    Feb 2017
    Birmingham, AL
    I see a lot of guys on here with the safety loops. Has anyone actually blown up a driveshaft, on one of these cars, and how much power did it take to do that?
    At what point when I am turning up my boost should I be concerned about the driveshaft?
    Jan 2016
    Winnipeg, Manitoba
    I also need one for a TKO 600. Will contact them to see what availability is.....
    On a roll Al_C's Avatar
    Wheaton, IL
    Another Metco recommendation here. I had the same question about availability. Apparently, they take orders and then do a production run to fill them all. If you're interested, I'd say call them and they'll let you know when they'll fill orders.
    Tybee Island, GA
    Quote Originally Posted by WarDamnEagle View Post
    The pinion angle was set incorrectly between the differential and the drive shaft which blew up the transmission, the drive shaft. Blew a hole through the floor board. Overall it did a lot of damage. Here is how it looked
    I too have the Metco Safety Loop - Just because Like John, I found that I need to put a spacer under the hoop to provide more room.
    20171217_211150 by D. R., on Flickr
    Videos are at: YouTube Videos
    Pittsburgh, PA
    "Has anyone actually blown up a driveshaft, on one of these cars, …"
    I recall seeing photos of a driveshaft failure posted on this board, and different from the one linked above. It was a pretty grim sight. Thus, even at a modest 340 horsepower I run Forte's loops around both u-joints on my coupe. At some point I may take the next step and put some titanium plate in the tunnel to act as a scattershield. I watched a rear u-joint fail on a big old 4x4 a few years ago and it too was a pretty grim sight.
    All that said, the Metco loops look like a really nice product, and I'd probably figure out how to run two of them if I were doing it now.
    Metco x whatever...
    Seasoned Citizen NAZ's Avatar
    Jacob, I've had two driveshafts explode on me and the damage they can do is impressive. No, not on one of these little cars but I'm sure even these short driveshafts can do significant damage. It's a smart idea to add driveshaft loops.
    Jan 2016
    Winnipeg, Manitoba
    I sent an email to Metco today Rick replied very quickly (nice to see) and said they have a batch in powder coat and should have them ready to ship next week at which time they will update their website....just thought I'd share the info.
    Mar 2017
    Had the same exchange from Rick.
    Gonna jump in line to order one
    Thanks again all for the input.
    I used the Lakewood Universal hoop. Very easy to fit and install. I mounted it to the 4" tubes.
    Senior Member 42Bfast's Avatar
    Feb 2017
    Pensacola
    My experience was with the rear u-joint on a 6cyl Jeep CJ7. By all accounts, not a high horsepower situation. The u-joint failed which allowed the driveshaft to fall free on one end and flail about wildly. Luckily, I was only doing about 30 mph and on the street, and was able to clutch and get stopped before any major damage. (I was in a turn through an intersection, the Jeep had an LSD, so there were stresses involved but nothing like what these cars produce)
    Bottom line, it CAN happen, when it does, the damage can be significant, not to mention potentially life threatening. The driveshaft loops are cheap, installation is easy (from what I can determine) can’t come up with many reasons not to install one.
    Purchased the Metco for my build, not yet installed.
    Having driven my old car, a 1995 Corvette, for over 20 years I had a 7 to 10 hour ritual that I performed every year.
    It was replacing the U-Joints in the half shafts because the upper links of the C-2, C-3 & C-4 Corvettes are the half shafts.
    It is why my car is a 3 Link rear and why it will soon have a driveshaft loop and side pipes if I can ever get home to work on it.
    I recently sold that car to a friend of mine for a whopping $2,000.00 dollars because his wife absolutely hates me, but that's another story.
    Shown Below Is That Car:
    https://youtu.be/svZX2BMSDEs
    A Driveshaft Loop Solves A Big Problem Before It Can Occur Plus It Can Save Your Life!
    Here is what mike looks like. Designed to limit shaft deflection angle if a ujoint fails.
  22. Likes cgundermann liked this post
  23. #22
    Jax Beach, FL
    The Metco loop was designed specifically for an FFR that they built in house. It is not one of the generic one size fits most pieces. Simple design, no drilling or welding.
  24. #23
    To each his own, but I wouldn't consider a loop with enough clearance to allow the shaft to droop beyond u-joint travel limits.
