Hi,
What are the reasons for a dual reservoir set up?
I have only had break leaks on really old cars that rusted.
Are there any times that they are required? ie. Road or drag racing requirements.
Hi,
Mk4 ordered 1/3/18, IRS, Coyote, T56 Magnum
One resevoir for the rear and one for the front in the event that you have a problem, you don’t lose brakes on both ends.
i don't race but added a second because i thought it looked better.20180407_162818_resized.jpg
I added a second reservoir too for redundancy with the thinking that if one brake system failed, i'd still have the other. However, what happens with the balance bar ? If one system fails, and there is no pressure, that master cylinder will have no pressure and the brake pedal will likely compress that cylinder only ? Any experts here that could give some information ?
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
As mentioned above, two separate reservoirs (one for eace M/C) makes for a completely divorced braking system front to rear. The Feds required separate braking systems way back in the 60's -- before that cars and trucks typically had one M/C for all the brakes. Even the common reservoirs have a divider wall to separate the fluid once it gets below the top of the divider so they are still truly divorced systems. You can figure out what happened when you had a failure in any part of the single system. And I have had such a failure on one of these early single brake systems and by pure chance lived to tell about it.
If you set up your balance bar correctly and have full travel on your M/C's you will still have brakes on one end or the other should one system fail. Leave too much side clearance on the balance bar or not enough M/C travel and you could end up defeating the safety aspects of a dual system.
MK IV Roadster #8631
the hose from each master cylinder to a single reservoir each act as reservoir. think we are talking semantics here. Again, I added a second purely for the aesthetics.
