Results 1 to 3 of 3
Thread: Rear hub bolts replacement - pretty snug to the hub seal
    Sep 2021
    Hello everyone. Newbie build #10314 up here in Canada. Get ready for the questions ha ha
    Just changing out the rear wheel studs on the hubs. The old ones have a notch cut out of the shoulder of the stud to allow clearance to the seal of the hub. Putting in the new studs looks like the shoulder will hit the rubber seal as it spins. or is this a normal fit? Any advice is very welcome.
    Nov 2021
    Schertz, TX
    I ground a flat on each one for clearance.
    Sep 2021
    Quote Originally Posted by sasteel43 View Post
    Thank you sasteel43 and TedG for your advice. Problem solved.
