Posted this on the other forum as well. Just wondering if anyone is at the stage of their build, or has their parts handy to give me the length of the swedged tubes in the 3 link set up. The shorter upper link and the panhard bar.
Higgy
Higgy
OK, different question. On the solid axle, using a donor axle housing(88-93) will the 95 and up disc brake brackets, calipers and 11.65 rotors all bolt right up if I'm using the proper length 5 lug axles?
Higgy
New MK4 kit ordered, promised date 04/13/24
MK4 #10616 picked up 4/10/23!!!
MK4 #9759 picked up on 4/3/19
Papa, was just the tube lengths. Yama-bro hooked me up!! Pan hard 37", top link 12" and VPM 5" if anyone else needs to know.
Higgy
Yes, I did exactly this and still was able to fit fat wide wheels in the back while maintaining the look I wanted. Rear tires are 315/35R17
Installed the rear axle and beautifully designed 3 link rear suspension with coilovers.
INSTALL VIDEO
https://youtu.be/zHZ7zCDX5t8
F5R9196 Hand built 347 475hp EFI | T5Z | LSD 3.73 3-link | Power Steering | Power Brakes | Vintage Air | 315/35ZR17 & 275/40ZR17 NT555
HAGERTY. DRIVERS CLUB | Texas Cobra Club
That's what I needed to know thanks! Also, after watching your video and a couple others I found out that in our set up if we switch the calipers, brackets and anti moan brackets to the opposite side, the calipers can be mounted on the front. Supposed to make for easier E-brake cable routing. You would have to remove your quad shock brackets though. Thanks again!!
