Results 1 to 8 of 8
Thread: MK4 Radiator Question
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    Guys
    I'm starting to mount the radiator on my build. Looking at the build manual, the radiator has many mount holes already made in the flanges on the top and bottom of the radiator. My radiator has no mounting holes. Did something change recently ? Do I just line it up and make my own mounting holes in the radiator ?
    Thanks!
    mark
    Build 1: Mk4 Complete Kit #9312 Ordered 1/27/18, Delivered 3/24/18, CA SB100 Registered 9/11/19 - Gen 2 Coyote TKO600, IRS, Power Steering, Wilwood Brakes, 17" Halibrand.
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    correct. i really suggest you look into buying the Breeze radiator mounting stuff upper and lower. I use it on all my Complete kit MK4 builds.
    http://www.breezeautomotive.com
    Fairfax Station VA
    Be advised you may have to clearance the out-board corner of the right side upper radiator mount. Or you may not, depending on the radiator.
    IMG_2698 by jhsitton, on Flickr
    MK IV Roadster #8631
    Mar 2013
    Medway, MA
    Jan 2018
    San Marcos, CA
    Mark, I just ordered the upper and lower mounting kits
    Tybee Island, GA
    Mark sells a quality product.
    Videos are at: YouTube Videos
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Very happy with Marks upper, lower rad mounts and his fan shroud.
    JR
    1. Mark sells quality stuff and I've got his seat brackets and his radiator shroud.
    2. I used his fan shroud as the frame for my radiator support and fan mount.
    3. The shroud is actually attached to the radiator and I built a "Breeze Inspired" system that can be seen in the attached video:
    25-30 Seconds In You Will See What I Did:
    https://youtu.be/PCngiKoopkA
    If you want to better support your radiator and I suggest you do, then consider his mounting system especially if you don't feel like going off the reservation like some people, namely me, by creating your own set up.
    Good Luck & You Can't Go Wrong With Mark's Stuff!
