Results 1 to 4 of 4
Thread: TKO speed sender
    Apr 2014
    Memphis, TN
    TKO speed sender
    I have a tko 500 and the Ron Francis harness and I am trying to figure out how to hook up the speedometer wiring. I assume I need to hook into the electric tko sender and not the mechanical because I have the electric gauges, but the plug in the harness doesn't fit the plug on the transmission. Am I supposed to get a new plug for the tko and put it in place of the other one?
    Ryan
    33 Hot Rod
  2. Likes Derald Rice liked this post
    Santa Clarita, CA.
    Read through this thread. You need the pigtail and also a plug. Fortesparts.com sells both. While you are at it you may also look into getting transmission spacers for the rear if needed.
    You need to call Mike. I have no idea how to find specific parts on his website but he does have what you need.
    https://www.ffcars.com/forums/17-fac...html#post87982
    F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
    Either sensor can be used for your electric gauges. Both output the needed signal for your speedo. The external sensor on the right side has the added option for an actual physical rotating cable (like the good old days) which obviously you don't need. There are two external sensor versions. One with the rotating cable connection, the other with it closed off. Keep it simple and just put the blocking plate on that side (not the shipping plug the transmission comes with) and use the internal sensor on the left side. I'm surprised your RF harness doesn't plug into the internal sensor connector. My last two Roadster builds plugged in without any changes. But as already stated, a pigtail with the proper connection is available and easily added to your harness.
    Aug 2013
    Gatineau, Quebec, canada
    We ran into a similar issue based on the way it sounds with our TKO600, take a peak at my build page post #111 & 113: https://thefactoryfiveforum.com/show...3-Hot-Rod-1028
    As well I posted a query on the FF 33 Hot Rod Builders FB page, look around the April 28th, May 3rd posts for Andreas Tanzer. I will be trying to attach a quick video my son made post corrections, hope this may help as the solution turned out to be quite simple. , this is how to connect your harness into the speed controller which has an effect as well.
