Results 1 to 7 of 7
Thread: upper or lower holes for shocks-
    Lake Mills, WI
    Guys,
    Where did you mount your shocks-MKIV-3 link rear, standard front width:
    Lower holes or upper holes on the frame shock mount areas?
    Martin
    That's a new feature added to some kits. The bottom holes are for "street" height. Top holes for "race" height, e.g. lowered. Assuming you want the street height, and are using the standard Koni's pictured, use the bottom holes.
    Lake Mills, WI
    Thanks Edwardb
    Appreciate it
    Martin
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Quote Originally Posted by magicmarto View Post
    Thanks Edwardb
    Appreciate it
    Martin
    They appear upside down based on the pictures in the "manual"?
    Quote Originally Posted by jwebb View Post
    Assume you mean the shock mounting? The standard red Konis can be mounted body up or body down. The manual does picture the rear standard Konis body up. But they'll work fine the other way as long as they clear everything.
    Wareham
    The second set of holes was added for the newer style twin tube adjustable Koni's which are slightly longer. Those are the aluminum colored ones as opposed to the old black double adjustables that had to be removed to adjust compression. Edward is correct that the red steel bodied shocks can mount either way, but the aluminum colored ones must be mounted body down.
    Jim Schenck
    Factory Five Racing
    Thanks Jim. Yea, I left some of that out because the OP didn't have the double adjustable shocks. These are the pages in the Gen 3 Coupe manual where this is shown. I'm assuming it's exactly the same for a Roadster since the suspensions are the same. I don't have the latest Roadster build manual.
    Front:
    Rear:
