Guys,
Where did you mount your shocks-MKIV-3 link rear, standard front width:
Lower holes or upper holes on the frame shock mount areas?
Martin
Guys,
Martin
That's a new feature added to some kits. The bottom holes are for "street" height. Top holes for "race" height, e.g. lowered. Assuming you want the street height, and are using the standard Koni's pictured, use the bottom holes.
Thanks Edwardb
Appreciate it
Martin
The second set of holes was added for the newer style twin tube adjustable Koni's which are slightly longer. Those are the aluminum colored ones as opposed to the old black double adjustables that had to be removed to adjust compression. Edward is correct that the red steel bodied shocks can mount either way, but the aluminum colored ones must be mounted body down.
Jim Schenck
Factory Five Racing
Thanks Jim. Yea, I left some of that out because the OP didn't have the double adjustable shocks. These are the pages in the Gen 3 Coupe manual where this is shown. I'm assuming it's exactly the same for a Roadster since the suspensions are the same. I don't have the latest Roadster build manual.
Front:
Rear:
