Results 1 to 4 of 4
Thread: Suspension travel
    Ol Skool
    upstate NY
    Suspension travel
    Thought some of you may like these.
    Front tires are 285/35/18 RS3 Hankooks, Rear are 345/35/18 Hoosier A7. Front still has 500lb springs and Koni's. Rear has Qa1 DD601 with variable rate springs. Greatly improved the weight transfer and eliminated the rear wheel hop and skip.
    Ol Skool
    upstate NY
    I have to give my wife credit for having the Digital Canon Rebel for the above shots. The car is a ball to drive and once I get some more tuning time will be competitive with a driver that can match the tires.
    Camber is about 2.5 degrees negative and Caster is about 7.5 degrees positive. 50/50 weight distribution with battery in back and full tank. About 2600lbs. The Hoosiers on rear are to limit wheel spin more than lateral slip. Car isn't quite pushing ...yet. Once it does push Hoosiers will go on the front. Driver isn't that quick yet.
  3. Thanks TxMike64 thanked for this post
    May 2016
    North of sacramento Ca.
    Thanks for pics!
    Senior Member TDSapp's Avatar
    Frisco, TX
    Quote Originally Posted by erlihemi View Post
    Nice pictures... Just think what she could do with a real camera, like a Nikon.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
