Results 1 to 6 of 6
Thread: PS oil cooler
    Mar 2017
    Norway / Merritt Island FL
    PS oil cooler
    Do I need to add an oil cooler to the PS? If so, recommendations?
    I am installing one for numerous reasons, might be needed, have one on hand, easier to do now, no down side. Mine is actually a Moroso trans cooler with an internal filter. I plan to start with no filter. I am running it on the return side of the rack back to the reservoir. I hope the FF reservoir is large enough, another reason, increased fluid capacity.
    Colorado Springs
    IMO, yes, absolutely. Even on the street, that fluid can get really hot. Put it in the return line, so it's low pressure.
    .boB "Iron Man"
    www.RacingTheExocet.com
    BTW Honda PS fluid from a dealer works better at high temps.
    Mar 2017
    Thank you for your inputs, gentlemen. One more point on the to-do list
    Pittsburgh, PA
    This is how I installed mine. The cooler is a transmission cooler made by C&R Racing. I can't speak to how well it works as the car isn't on the road yet.
