Results 1 to 4 of 4
Thread: crank position sensor
    Saline, Mi
    Trying to start car, 2002 WRX engine, using Microsquirt V3 and am not getting a rpm signal when I datalog engine parameters when I crank it over.
    Subaru manual says +- 7 volts when running but it is a VR sensor so its output varies strongly with crank rpm. I am seeing about 2.5 v peak to peak.
    Anybody looked at their crank sensor with scope or know what MS v3 needs??
    Charm City
    I had a MS v3 on a Mazda do that to me once. We scopeed it and it showed all kinda of weird behavior, found the wiring bad from the plug and pray mega squirt harness I had bought was: 1. not shield properly or good enough and 2. a pin on the sig wire at the sensor connector was crimp improperly.
    FFR 818r Instagram biknman69
    • Ernest Hemingway
    Feb 2013
    Copperas Cove, Texas
    Did you add a resistor to the wiring for the crank and cam sensors?
    -Jason
    Saline, Mi
    Fixed. Someone, possibly me gg, connected to optio input,
    not the VR input although I knew the sensor was VR.
    Recoonect to proper pins on MS V3 and
    "magic", It works. Not the 1st dumb thing
    I've done on this project.
