Results 1 to 4 of 4
Thread: crank position sensor
    Saline, Mi
    Trying to start car, 2002 WRX engine, using Microsquirt V3 and am not getting a rpm signal when I datalog engine parameters when I crank it over.
    Subaru manual says +- 7 volts when running but it is a VR sensor so its output varies strongly with crank rpm. I am seeing about 2.5 v peak to peak.
    Anybody looked at their crank sensor with scope or know what MS v3 needs??
    818r center seat biknman's Avatar
    Charm City
    I had a MS v3 on a Mazda do that to me once. We scopeed it and it showed all kinda of weird behavior, found the wiring bad from the plug and pray mega squirt harness I had bought was: 1. not shield properly or good enough and 2. a pin on the sig wire at the sensor connector was crimp improperly.
    FFR 818r Instagram biknman69
    2020 Ram 2500HD, 19 Forester Touring DD, 96 GM coupe for SCCA SM
    “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
    • Ernest Hemingway
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    Did you add a resistor to the wiring for the crank and cam sensors?
    -Jason
    Saline, Mi
    Fixed. Someone, possibly me gg, connected to optio input,
    not the VR input although I knew the sensor was VR.
    Recoonect to proper pins on MS V3 and
    "magic", It works. Not the 1st dumb thing
    I've done on this project.
