Thread: 94-04 Donor Gas Tank Question
    Mar 2018
    2002 Donor Gas Tank pictured, getting ready to mount the tank after some prep work. What do I do with the big black cylinder that is attached to it?? My plan up to this point was to keep as much of the OEM parts as possible within reason, aside from easily removable emissions stuff. gas tank.jpg
    Good Luck - the tank pictured has nothing to do with 94-95.
    Here's the best I could do last time i got to looking about it:
    https://thefactoryfiveforum.com/show...r-New-Gas-Tank
    Mar 2018
    Edited to reflect year of tank. Does anyone else have any experience with this?
    Indy Shu's Avatar
    Indianapolis, IN
    That's the vapor canister to vent the tank and the fill tube. I had mine all connected originally including the elect plug from the donor harness. When the mounting bracket broke I took it off and have had no issues with gas odors. You may want to do a search for a simple homemade version that is smaller and lighter. hth
    Gen 3 Coupe #334 received 11/4/21. Coyote, IRS, TKX, Wilwoods
    '02 GT donor, 4.6 sohc, Received #5488 on 5/29/06. 3-link, ps, pb. Hoosier Cobra member (Hoosiercobra.com)
    Mar 2018
    Did you plug the vapor lines that run to the front of the vehicle as well?
    Indy Shu's Avatar
    Indianapolis, IN
    It's all connected almost exactly like on the mustang, but replaced a couple of lines with rubber fuel hose. All still there except for rear canister. Just left the line open ended, no issues.
    Dec 2017
    Southern Ontario
    Search 'Carbon vapor filter' in Shark92651's build thread. He makes a slick one out of a pop up sprinkler head.
    Higgy
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
