Results 1 to 10 of 10
Thread: 3rd / 4th gen Doner
    Aug 2018
    3rd / 4th gen Doner
    Hi All,
    Can anyone advise the problems associated with using a late model donor for the 818?
    AFAIK, we need to pass current emissions regulations with an independently constructed vehicle in Australia to register. This will likely be easier to achieve with a late model motor than it will with an older platform.
    The other pro for later model wrecks compared with older cars is the much lower km's they've traveled. It seems a lot more likely you'd get hardware in re-usable condition from a low km donor than a high k one.
    I've copied the donor parts required list from FFR website below for reference:
    Front spindles with full brakes and front lower control arms
    Rear spindles with brakes and E-brake handle/cables
    Steering rack, tie rod ends, and upper steering column assembly
    Pedal box and throttle pedal
    Master cylinder and brake booster, and clutch master cylinder
    Engine with turbo and intercooler (if WRX model)
    Exhaust manifolds, O2 sensors, and down tube
    Transmission
    Rear lower control arms, toe links, and CV joints
    Front seats, front seat belts, and gauge pod
    Fuel pump and fuel level assemblies
    Radiator and fan
    Wheels and tires
    Door hinges, rear with latches, strikers, and inside door handles
    Side view mirrors, left and right
    Rear view mirror
    Rear seat belts
    How much of the above from a gen 3 or 4 is incompatible with the 818R kit?
    Saline, Mi
    I would get in contact with Iwire, the vendor that builds harnesses for these builds.
    They are likely to know the details of using a late model with can bus etc
    Aug 2018
    Thanks Frankc5r,
    Brian has been very helpful from Iwire and advised that the CANBUS system was introduced in the 2008 model subaru. Iwire are working on a CANBUS emulator that will make life easy, in the mean time however it is easier to use an older model ECU to control the engine.
    With the electrics on the way to being sorted, Is it then possible to use the remaining required hardware from a 2008+ model in place of the pre2008 donor parts? Do things like the steering rack, pedal box, half shafts etc all fit into the 818?
    Saline, Mi
    Wish I could help but I am fairly new to Subaru.
    San Diego Ca 92106
    In 2008 Subaru had a major update to the Impreza running gear including the suspension parts. You have to decide whether modifing the frame to accept later year parts is worth the effort. Others have totally redone the suspension, they have serious skills and have shared their progress here on the forum. I on the other hand have modest skills and found that refurbishing the parts will make them like new.
    Aug 2018
    Thanks Flynntuna,
    Makes sense that there is geometry differences as the track changed I believe. Do you have a link to any of the build threads in which people have used the later model running gear? My search skills must have gotten rusty, as I have been unable to find any information whatsoever on the later model platform being used as a donor.
    San Diego Ca 92106
    The link posted is to "Lance's 818s". He went with Corvette suspension.
    I've been on the list since before the first 818 was delivered. I don't remember anyone going with a later generation "Subaru" suspension. Please correct me if I wrong.
    San Diego Ca 92106
    No one who has posted on the forum has gone with post 07 suspension that I've seen either.
    Here's another thread I've found...
    https://thefactoryfiveforum.com/show...DanielsDM-818R
    Leesburg, VA
    Here are two more examples of 818 suspension modifications I could think of -
    08 Legacy rear suspension rework:
    https://thefactoryfiveforum.com/show...l=1#post263119
    S2000 front spindles:
    https://thefactoryfiveforum.com/show...l=1#post182669
