Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Help ! 1990 T-bird 8.8 IRS oil seals? Part number?
    Member CNIdog's Avatar
    I've been trying to get axle oil seals for the 28-spline IRS pumpkin for the left and right side. Every part store, including Ford, order in seals which are way too big. (31-spline?)
    Anyone have the part numbers from any source ?
    I have a 8.8 pumpkin with casting code that looks like RF.E95H-DA rev E
    tag codes is 3L27 (327 ratio traction-lock) 8.8
    model S511B
    build date: 0C17 - 1990 March 17 (St Patricks day which may explain it all ;-) )
    Senior Member karlos's Avatar
    Littleton, CO
    Photo below shows what was in the box of parts that came with my rebuild kit. M-4413-A includes the bearings and the seals; about $30 from Summit (https://www.summitracing.com/parts/fms-m-4413-a)
    Sorry but I can't find the part number on just the seal alone.
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
  3. Thanks CNIdog thanked for this post
    Sacramento CA
    Look for a part number on the seal!
    If the seal is out, go to a bearing supply company with it and they can find one for you!
  5. Thanks CNIdog thanked for this post
