Thread: Mounting rear license plate issue
    Member BobCarter's Avatar
    Jun 2015
    Springfield, MO
    Has anyone had a issue when mounting their state issued license plate on the trunk?
    My problem is this, the lower edge of a Missouri plate doesn’t clear the trunk latch handle.
    What to do? Cut a clearence opening in the lower edge of the plate? Don’t think our state police would find this accep.
    All suggestions are welcome. Thanks
    The "Kleiner Mod" is one that many use:
    https://www.ffcars.com/forums/17-fac...ml#post2455581
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Santa Clarita, CA.
    Yup! Kleiner mod here as well.
    F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
    This is discussed a lot. I've personally done the "Kleiner mod" a couple times. For #8674, also switched the incandescent bulbs for LED bulbs. A really nice mod copied from another forum member. MAL-S-WW2 Warm White with Silver Housing, LED license plate bolt lights from superbrightleds.com. Not only do they provide better light, longer life, and lower current draw, they are sealed and water is not an issue. The lights need to modded anyway, so it's really easy just to replace them with the LED's. These are pics from my build. Also requires the different mounting bracket shown, an easy fab from a piece of aluminum.
    #9160 BB767's Avatar
    Chehalis, WA
    Or just do this. You don't even notice unless you look closely.
    MK4 - complete kit - Blueprint 427W - Holly Sniper EFI - TKO 600 .64 - 3.55 3 link - 17" Halibrands
    So. Bay (So. Calif.)
    Kleiner mod here too. I converted to LED's with the mod. Plus, during the body work, I had the pad on the trunk lid centered to the right a bit, and moved up about a 1/4 inch or so. That took care of having to notch that last little bit of the bottom of the plate.
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    Like has been already said... Kleiner Mod. My personal take on it. Used a small pair of low profile LED lights mounted up inside the housing.
    And a simple metal trim ring, cut down and holed out to keep the edges looking cleaner... er.. Kleiner?
    2016 MK4 | '99 Explorer 5.0 | E303&600cfm carb | T5z + 3.55 | 3-link | SN95 | PB/PS | FR500 17" 315&275 |
    Raleigh NC, OIB NC
    Modified the Kleiner Mod slightly. Noched the plate at the top & wrapped the cut in electrical tape. Did not change the electrics. Cut a slot in the lense & bonded the plate to the FFR cross piece. Did not touch the bottom of the plate because I wanted the "1965" to show.
    Kevin
    MKIV #8234
    Senior Member JIMOCO's Avatar
    Aug 2013
    Camp Hill, PA
    20150812_172845.jpg I cut a hole in mine. I was told that as long as the state name and your number are visible there should not be an issue. I added a frame and LED back-up lights.
    Mk4 Roadster, Picked up complete kit 8/22/14. Most FFR options except Wilwood brakes and IRS. First start 11/11/14. Go-kart 3/8/15. 347 Stroker, TKO 500, 3-link/3.27 rear. PA street legal 7/29/15.
