Looks as though I may be following the Canton 90 degree rotating adapter route. I've used the supplied remote, and believe that I'm starting to develop a leak where it seats against the block.
I have a small block ford 302 and this appears to be the model that I need for my engine.
Note: I am using the J-pipes and supplied OEM headers. Things are tight where this adapter threads onto the block in that area already. Can someone confirm that this is the model that I need to fit in my tight space? I considered the 90* unit, but am unsure if it will fit in my space.
20170601_225144 by D. R., on Flickr
