Results 1 to 7 of 7
Thread: Windshield Rattle
    NY
    Windshield Rattle
    It seems there is a rattling noise when driving, like its coming from the windshield, but its rock steady, could the body be rubbing on it ? Wierd
    Richmond, Texas
    Rattling Noise
    Quote Originally Posted by bil1024 View Post
    I had a noise similar to what you are describing. At 1st I thought it was my glove box, but it ended up being my passenger door rubbing against the body near the top by the windshield support. It did sound like a rattle. My son actually found it. He placed his hand on the top of the door & it stopped. I tried a little stip of electrical tape on the inside edge of the door & the noise stopped. Maybe you have the same problem. Give it a try.
    bobl's Avatar
    Spicewood, Texas
    I chased a similar noise for quite a while. Turned out to be the hood latch not being tight enough. Sure sounded like it was coming from the dash/windshield though.
    Tybee Island, GA
    Hope you find your rattle. I've got a rattling behind my left shoulder. Driving me silly trying to find it.
    Videos are at: YouTube Videos
    Also check that the holes in the fiberglass are large enough so the windshield posts don't touch the fiberglass. And look on the inside of the w/s post at the lower corner of the w/s frame. Do either of them touch the fiberglass?
    Alliston, Ontario, Canada
    Does it happen at all speeds and engine rpm or variable? I have a resonant vibration from my engine at about 2100 rpm. It was making my air cleaner sound like singing anytime the engine hit that rpm. I tightened it and it went away. Now it vibrates the body right about where the mirror attaches above the dash.
    Good luck sorting it out.
    NY
    Its usually just happens while driving normally, worse over bumps
