Results 1 to 3 of 3
Thread: Different gas tank found
    Member CNIdog's Avatar
    I've been planning an under car exhaust for my early MKIII with IRS and wanted to put the mufflers in the back end under the trunk but, the mustang tank takes up the space.
    here's what i got. It's a '53 Chevy replacement tank. I holds as much gas and wastes less space, fits between the bumper bolts (No Molotov Pinto, thanks) and leaves me lots of room to fit whatever muffler setup I like.
    There 3 different ports for the filler. You can order one of 3 models or cap it and use another which I may end up doing. Some simple frame mods are needed the strap mounts...
    I had to cut the front mounting brace assembly due to the tank being 19" deep. 28" wide and 8"high. There a wider version too if you want 3 gallons more.
    Aug 2017
    Michigan
    Nice! Are you going to run the pipes under the rear suspension?
    2.5 inch pipes to the back under seats and along the IRS frame then out to either side to a pair of Cherry-Bomb Vortex... should breath OK
    I'm leaving the engine as stock '87 HO cam and heads for now. Using a FiTech on a Performer
    RPM manifold and a Flame-Thrower distributor. Just bolt on stuff for now. I've been stalled on this build for years. :-)
