Thread: Roadster Ride height
    Senior Member Kodiak's Avatar
    Jun 2020
    Pinckney Mi
    What is the baseline setting for ride height ? And how do you determine what is good / bad for your build ? 427W, IRS regular konis 17s 255 front 315 rear. Thanks Fellas.
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    I have same setup as you, I am about 4 1/8" front and 5 1/4" in the rear. I wanted at least 4" in the front to clear a speed bump, after looking at many different FFR cars recently everyone has there ride height a little different.
    Front 4.0 inches and rear 4.5 inches would be a pretty conservative baseline. Some will run higher, some lower. Also depends on the age of your car. If a new build, you could start there but monitor. It will settle some.
    Edmonton Alberta
    I run mine a little lower 3 3/4 front and 4 inch rear. Note they will settle maybe up to 1/2 inch after driving 30 min so start a little high. Ride height can change the alignment. Get the ride height set then get a final aligment done.
    David W
    Mkll 4874 built in 2004
    Senior Member Rdone585's Avatar
    Jul 2020
    Near Milwaukee, WI
    Also, know that not all tires have the same diameter. So if you put a tire with a smaller diameter the actual chassis to ground surface (i.e. ride height) will change. I have 4 sets of wheels and tires. One of the sets gives almost 1/2" taller ride height than the others. That's not a problem, just something to know about. I set the ride height based on knowing they are different.
    MkII: 408 Dart block dry sump, 750cfm carb, G-Force T-5, 8.8 rear with 3.55 gears, 3-link, Kirkey seats, black ceramic coated twister mufflers with shields and adjustable turn down tips, passenger roll bar, front and rear roll bars. 2020 GT500 Magnetic metallic, with white and lime green stripes.
    On a roll Al_C's Avatar
    Wheaton, IL
    Mine is at 4 inches all around. The key to speed bumps isn't necessarily your ride height; it can also be a matter of where (relative to the frame) your bell housing is. As many others have done, I had to trim mine.
    Raleigh NC, OIB NC
    Mine is 4" by 4 1/8" Bellhousing is tucked but frame would drag on some speed bumps at 3 7/8"
    Kevin
    MKIV #8234
