Thread: Rear Wiring Harness Advice
    Mark Eaton's Avatar
    Oregon
    I'm getting ready to put in the rear wiring harness. I know it is pretty straight forward to just follow the build manual but I was wondering if anybody had any simple do's or don't that I may not have read in other build threads. I am planning to put in back up lights, extra brake lights on the rollbars, and a trunk light, so any help with this would be great. For me it seems the wiring is the most intimidating part of the build so any advice, the simpler the better, is greatly appreciated!
    Mark
    Senior Member RJD's Avatar
    Northern, VA
    My EFI ECU had it's own relay and fuse and controlled the fuel pump, so I had to incorporate that wiring in with the rear harness to the fuel tank. Just something to consider.
    Really not too much to say. The stock RF rear harness is OK as is. Typical to route it down the top inside corner of the transmission tunnel, underneath the trunk floor, and then route from there to the various lights, fuel tank connections, etc. If you're installing a dropped trunk box mod, you'll have to route it over a bit once in that area, but there's enough length to do it. IMO, the fuel pump and sender harness legs are way too long. I shorten them. But if you're not comfortable doing that, leave them as is. No big deal. For the added wires, kind of your choice on what you want to do. If you're comfortable with it, easy enough to unwrap all the electrical tape, remove the convolute, add what you need, and then wrap it back up again. Or you could run them in a separate smaller harness. The added brake light can be tapped from the existing brake wire. You'll need to add wires for the backup lights, including a pigtail connection to the transmission, and trunk light. Then decide where to get the source voltage from under the dash. For the backup lights, any ignition circuit could be used. For the trunk light, could be on the courtesy light circuit so when you twist the headlight switch the trunk light goes on. Or you could hook it to a battery circuit (always on) and have a switch on the trunk lid so it goes on when opened. I've done both and do prefer the latter.
    Build 3: Mk4 Roadster 20th Anniversary #8674. Sold 09/07/2020. Build Thread and Video. Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Legal 03/04/2020. Build Thread and Video
    Build 5: 35 Hot Rod Truck #138. LS3 and 4L65E auto. Rcvd 01/05/2021. Build Thread
    Mark Eaton's Avatar
    Oregon
    Thanks Paul, thats exactly what I needed to hear.
    Mark Eaton's Avatar
    Oregon
    Quote Originally Posted by RJD View Post
    Thanks, I have EFI also so I'll check on that.
