Results 1 to 12 of 12
Thread: Boss 351 Block Question
    Senior Member cv2065's Avatar
    Anyone know if the Boss 351 block mounts just like the older 351W block to the provided FFR mounts? Any clearance issues of any kind? I think I'm going with a 427 stroker, and seems like there are some pretty good deals on Ford Performance long blocks. Thanks!
    I have the Ford Racing 427W stroker which is based on the 351W Boss block. It bolted right up with the FFR provided engine mounts so I would say YES.
    Quote Originally Posted by KauaiMK4 View Post
    Awesome. Thanks!!
    Mar 2017
    Norway / Merritt Island FL
    How much power are you aiming for?
    Quote Originally Posted by Sigurd View Post
    Entry level for the 427. 450HP and a little over 500 torque.
    One other question on this. I'm looking at the Ford Performance 427 x-Head crate engine. Says the X-Heads exhaust ports are raised 5/8" and may require custom headers. Anyone have any experience with this and if the FFR headers will fit with no issues?
    Senior Member kobra01's Avatar
    Mar 2013
    Chino Hills, California
    I have an x427 in my car. I am not a total gear head but this is what I think. I could and probably am wrong.
    x-427 is discontinued. It has oem exhaust and intake locations. If you can find one it should work for you.
    z-427 is discontinued. The exhaust ports are raised on this engine and could cause you some fitment problems.
    Ford Performance now sells a Z2-427 and the intake and exhaust are in oem locations. This may work for you.
    You would have to talk to someone knowledgeable about the oil pan on the Z2-427 to see if the pan depth is okay. I had to change my pan because it was a rear sump and hung below the frame.
    Also because of the headers (not the factory 4 tube headers) and j pipes on my car to accommodate fuel injection some modification was required on the driver side foot box to allow for the headers. If you ran the regular 4 tube headers the box may not need modification.
    MK4 Roadster # 8548, Ford Performance X427, TKO 600, 8.8 3 Link, Paint by Jeff Miller, Suspension setup by Frank Maslowski I.E.427
    Senior Member Crawleyscobra's Avatar
    I've got the Z427 with the Z304 raised port heads and I had to have custom headers made. As for my rear sump it is level with my frame.
    FFR6682 - received 7/30/08 - MK 3.1 complete kit, Forte built Ford Racing BOSS 427W(475HP/500lbs), TKO600, Power steering, Power Brakes, Hydraulic Clutch, VPM Front/Rear sway bars, Bump steer kit, SAI mod, 13"Front/11.65"Rear Mustang Cobra rotors w/calipers, NITTO NT05s - 255/40R17-Front, 315/35R17-rear,3.55 IRS.
    Visit my Blog: http://crawleyscobra.wordpress.com
    I've got the discontinued 427X. Gas-N Stainless 4 tube 351 headers work fine with ports in oem location. Bought a rear sump engine due to availability, then swapped pan with a 7.5" Canton kit from Breeze, sits level with bottom of frame. If you can still get one of these, get it.
    I also have the X-heads with the stock front sump and have no major fitment issues. I am using the FFR exhaust pipes and needed to add the Breeze spacers on the passenger side to lower the pipes a little but this probably varies with each build frame and body. I possibly could have corrected this without using spacers by adjusting/notching the engine mounts/frame tabs and slightly rotating the engine but using the spacers were a much easier fix.
    Senior Member CFranks's Avatar
    Mar 2018
    Berwyn, PA
    I have the 427X as well. It’s Awesome! Probably the coolest thing I own. Like everyone sais fits in fine. The only slight challenge I’m expecting is that when I drive it around in gel coat before paint and bodywork, if I wait a bit and don’t cut the scoop hole, might have to get a different temporary air cleaner due to the slightly higher deck height. Tons of people have them so shouldn’t be an issue in general.
    Thanks guys! Now it’s just a matter of finding one. I thought I had a bead on I one at my local Ford dealer, but they no longer have it. Trying a couple other places. If anyone knows of a new one, just let me know. I’ve read that you can’t use the z heads on the newer model because of the 5/8 raised exhaust port, unless you want to buy new headers.
