Experiencing fluctuations in oil pressure, it moves from say 60 psi to 75 then to 50 all while engine running at virtually the same RPM. I replaced the sender but the problem still exists, any history with Speedhut gages having issues? The sender is mounted directly to the block through some brass plumbing..
