Results 1 to 5 of 5
Thread: Wood dash question
    Senior Member Jdav's Avatar
    ATL GA
    Wood dash question
    For those of you who have done a wood dash, what brand and color of stain have you found to best match the steering wheel?
    MK4 #9028 - Coyote - TKO600
    Delivery: 1/30/17 First Start: 7/23/17 Legal: 10/5/17 Graduated: 10/15/18
    Build thread: http://thefactoryfiveforum.com/showt...8-Build-Thread
    Planning updates already, eh? The stain color will vary greatly depending on the wood species; i.e.; the same stain will be different on red oak, white oak, maple, poplar, pine, etc. You'll need to select your wood then do some sampling to make a match. Also keep in mind that sun exposure will change the color so it will need to be topped with a UV resistant clear finish---note that the term is "UV resistant" so don't expect it to stop 100% of the change that comes with long term exposure.
    Senior Member SingleMaltWSKY's Avatar
    Jan 2016
    Can confirm. We had LOTS of sampling before we made a choice on the type of wood as well as the stains/finishes. The good news is that depending on your local wood supply the samples will either be free or super cheap, so it's mostly time.
    Also, we chose to go with a wood veneer over an aluminum sheet to avoid cracking due to weather/temp changes.
    Jonas
    _____________________
    Check out our build blog - https://vjjfactoryfive.wordpress.com/
    FFR Type-65 Coupe 720
    London Ontario Canada
    ATL GA
    Sort of
    Dash is staying as is, but I am attempting to do a wood overlay on the door sills instead of carpet. My initial work has been done in red oak.
    Feb 2017
    Ours turned out to match very well. I used a walnut veneer from Constantine’s, then purchased three different sample size stains from Hone Depot and produced several small samples on circular pieces of aluminum. I put resin over all three in order to know exactly what the finished product would look like and how closely I could match the steering wheel. I believe it was minwax “honey” or something like that. Once I did the dash it only took three tries to get the resin perfect... but I persisted because my wife really wanted the wood dash. In the end, it turned out beautifully.
