I'm with Kevin (BEAR-AvHistory). Go the route that Ford intended for the coyote. Get the Moroso tank and the extra hoses. The hardest part is mounting the tank. Fabricate a couple of brackets to mount to the frame cross member above the radiator, attach another bracket on the bottom to steady it, and you're good to go.
