Results 1 to 4 of 4
Thread: 4 Link Rear Axle Caliper Brackets confusion
    Senior Member NA5KAR's Avatar
    Jun 2018
    Coral Springs, FL
    Did you ever see Beetlejuice? The ghost couple couldn't figure out the 'Handbook for the Recently Deceased'. That's how I feel reading the FFR manual. Anyway, kidding aside, I bought the Moser rebuilt rear end from FFR with my kit. I also bought the 11.65 rear brake package from FFR. I purchased and installed the 7106 Moser cover (Summit Racing) and replaced the ugly chrome one. Now I'm on to the brake installation starting with the Caliper Brackets. Dan's video (FFR) shows him removing each axle to install the caliper brackets. When I looked for what came with my kit, I was relieved to see the open end brackets. I guess I don't have to remove the axles. However, my brackets (pictured below) are in 4 pieces. I can't find a single picture or drawing about how to orient, stack, or install these brackets. Any help would be very much appreciated. I would hate to wing it and get it wrong.
    PS. I have been looking through posts and I see some calipers are mounted on the lower part of the rotor and some are higher. Adds to my confusion. Thanks.
    Dan
    Alliston, Ontario, Canada
    I feel like this was in the back of the manual for optional rear brakes and showed putting the brackets together. I have the same brakes but got them and different brackets from fortes.
    Caliper should be above the axle, I have 3 link and mounted them forward of the axle, not sure what the 4 link setup requires.
    Dec 2017
    Southern Ontario
    Quote Originally Posted by NA5KAR View Post
    Dan
    Try this link Dan
    http://www.factoryfiveparts.com/cont...ions-rev-c.pdf
    Comes from the FF parts web site, under the heading of instructions at the top. Lots of good direct links to stages of the builds there.
    Higgy
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
    Jun 2018
    Coral Springs, FL
    Quote Originally Posted by HiggyMK4#???? View Post
    Try this link Dan
    Higgy
    Higgy ... You are a LIFESAVER! This is exactly what I need.. Thanks a million.
  5. Likes Higgybulin liked this post
