Results 1 to 12 of 12
Thread: Rear end needed to tuck FFR 18" Halibrands?
    Dec 2013
    I'd like to get the 18" rim option, but I want them to tuck under the rear fenders. What rear end option should I choose to get them to tuck?
    Thanks!
    Fox width.
    Dec 2013
    Fox width.
    Can that be purchased from ffr? I dont think i saw that as a customization on the ffr site.
    May 2016
    Yes
    Quote Originally Posted by mike8082 View Post
    The optional Moser straight axle rear end is the proper Fox width as is the IRS.
    Guys, double check me, but I think the width wheel mount surface to wheel mount surface is 59 1/4 inch.
    Dec 2013
    I see a "narrow" option. Says 5 inches shorter than standard. Is that the fox width?
    Lilburn, GA
    Yes, Fox body is 59 1/4". I have a solid axle with 17 x 10 1/2 wheels. Purchased mine from MPS Salvage in Statham, GA 30666 800-236-1156 (770) 867-0863) Totally rebuilt with new gears (pick your ratio), bearings, clutches, 5 lug axles and brakes (Ford) ... just add fluid. $1750 plus tax. ($1500 without brakes)
    No. Fox width is standard.
    May 2016
    I have a fox axle with sn95 big brake "Cobra" Calipers. Its a bit wider with the big brake swap but still tucks the tires. I run the biggest 315mm tire you can get on a 17x10.5 wheel under there just for an example.
    Senior Member SSNK4US's Avatar
    Bakersfield, CA
    I have the Moser supplied FF complete kit rear end out in the garage in the crate. I’ll go measure it. I believe the narrower axle your seeing on the FF website is for pin drive (real knockoff) wheels ?
    Kurt
    Build thread
    May 2016
    What SSNK said, the narrow axle is for the pin drive stuff. Regular or fox width is what you need.
