Boig Motorsports is having a September 10% off Sale on ALL Cooltubes for Roadster, Coupe, Hot Rod, and 818. Order at www.boigmotorsports.com
Hmm. May need to order upper and lower for my ol’ Mk1 to help update the under hood appearance. I’m using the latest FFR radiator.
Mark
Mburger; Got those hoses in stock!
Hi Bob,
I hope you don't mind me chiming in. Let me state right off the bat that I purchased a set of tubes from Boig and recently replaced my flex-line hoses. So this is a non-paid endorsement.
Here's where I started. The lower contacted the driver's tow hook:
It was just starting to leak fluid:
The upper was just ugly:
The new lower hose clears the tow hook by a mile:
...and the hose fittings had enough play so that I was able to use the frame hose clamp from the original build. The bends are perfect and the hose goes together like butter. No more adapter hoses!:
For the new upper it went in like a glove too; and will look even better once I change out the upper overflow hose to braided stainless:
Again, I wasn't paid for this endorsement. I just really love my new cooling tubes!
