Slot in door for power windows
OK, I have read many of the posts for installing the power windows and understand its a PITA, but following the directions for cutting the slot you measure in .500, then out .375 giving you a slot of .875. The felted rubber seal is .950 wide with .400 clipping onto the door leaving .55 covering the slot. With both seals on each side of the slot gives a .225 overlap.Sept 2018 007.JPG The glass is .200 thick, if you set it up leaving .100 between the seals for the glass to go between, shouldnt the door slot be .325 wider than what it calls for?Sept 2018 012.jpg. Am I missing something? I have run the window up and down in the "narrow" slot and the window seems to seal well against the hard top seal, so wider on the inside or out side or split the difference?
Also when you install the vertical U channel that really crowds the door handle cableSept 2018 010.JPG
