Results 1 to 5 of 5
Thread: Converting to 3 point seat belts
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    Hi
    I am looking for ideas for mounting 3 point seat belts instead of a harness on the 33 Hot Rod. I know I have seen this in the past but I can not fine them now that I am ready. I am having trouble fitting the pull cartridge next to my Boyd tank. I know lots of you have done this and I would like to know your solutions.
    TomH33
    Oct 2014
    Vermilion, OH
    Tom,
    I mounted my retractor on the lower outside bracket for the lap belt, and used .250" wall tubing for the upper mount with a .250" top plate. I drilled and tapped the top to accept the upper bolt and mounted the tube into the roll bar mounts. I hope that makes sense, if not hopefully the pictures help.
    CVOBill
    I wanted to keep my roll bar so used a roll bar accessory clamp from Speedway Motors p/n 91032866. and mounted the retractor on the lower out side along with the lap belt
    Ol Skool
    upstate NY
    With the accessory clamp I actually was able to have both the 3 point and the Simpson harness coexist. 3point lets me reach the "comfort" accessories for street drives.
    I welded two tabs to the roll bar and pinned it. The tabs sticking out were worrisome but I can turn the roll bar around so the tabs face backwards, maybe. I did not use retractable belts, I could not get the retractor in at the bottom mounts. I presume I could have put the retractor on the tabs. Last pic is for contrast. I did not mind the harness but my wife hated it.
    IMG_0142.jpgIMG_0138.jpgIMG_0184.jpgIMG_0183.jpgSeq-17c6.jpgSeq-17g1.jpgSeq-17g8.jpgSeq-17h2.jpgSeq-17i1.jpgIMG_3479.jpg
